Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
- Model: NVIDIA AA6000
- Driver Version: 535
Topic Description
Hi everyone,
I’m working with the team on porting a custom reinforcement learning algorithm from Isaac Gym (Legged-Gym) to Isaac Lab using Isaac Orbit, and I’d really appreciate any advice or guidance from the community.
The original implementation is based on the paper:
“Learning Humanoid Standing-Up Control Across Diverse Postures” by Tao Huang and partners.
The code is built upon Nvidia’s Legged-Gym library (using Isaac Gym), and defines a multi-stage standing-up behavior for a humanoid robot. The agent is trained with PPO and leverages custom design features like:
- Multi-critic reward optimization, grouped by task stages (righting, kneeling, rising)
- Curriculum learning, with a vertical force applied at the start of training
- Action rescaler β to control joint speed/torque smoothly
- Smoothness regularization to reduce oscillatory motion
- Domain randomization for sim2real transfer and terrain diversity
I want to recreate the same learning environment and behavior inside Isaac Lab, using the Orbit framework. Specifically:
What I’m looking for:
- How can I implement a multi-critic RL setup or simulate one using Orbit’s task and reward structures?
- Any recommendations for building custom curriculum learning (applying force, changing difficulty)?
- Best practices to add a PD controller with action rescaling β to a humanoid robot in Isaac Orbit?
- How to separate and log multiple reward components (for better interpretability / debugging)?
- Examples of domain randomization and initial posture variation using Orbit’s Scene + Randomization API?
- Are there existing examples or repos that implement something similar with humanoids in Isaac Lab?
If you’ve worked on similar problems or have seen relevant examples, I’d love to hear from you. Thanks in advance for your time and any suggestions 🙏
Best regards,
Francesca
