Are you using the devkit or custom board for Orin NX?
Sorry that I’m not clear about what’s your exact use case to perform them.
As my understanding, jetson-io should work on the devkit if you don’t manually copy/modify any dtb file after fresh flash.
No, I have a orin nano development and orin nx module, and then I combine the orin nano carrier (P3768-0000) and orin nx module (P3767-0000) together. And then I build a yocto sdk for orin nx module with below link
but the rootfs doesn’t include the jetson-io utility, so I want to port Jeston-os utility into yocto rootfs
I have fix some issue, and jetson-io.py can start up, but when I use it to setup pin, it reports below error
