Hello Community.
I have to port a code from C++ to Cuda. The code use an object that use its internal function to do a simulation. This object use mostly simple mathematical function but it use also a lot a random number generator function. I though that I could replace the random function with an internal random function of the object and then use it in the kernel. To show you what I need I wrote a toy model that is an extreme simplification of what I need.
#include <cuda.h>
#include <iostream>
#include <curand_kernel.h>
using namespace std;
struct test{
float value1;
float value2;
curandState B;
float __device__ rand(){return curand_uniform(&B);}
__global__ void setup_kernel(curandState *state)
const int id=blockIdx.x;
curand_init(id, id, 0, &state[id]);
__global__ void fill_mat(struct test *anobj, curandState *state)
const int Idx=blockIdx.x;
curandState localState = state[Idx];
anobj[Idx].B=localState;
anobj[Idx].value1=anobj[Idx].rand();
anobj[Idx].value2=anobj[Idx].rand();
int main()
int num=10;
curandState *devStates;
cudaMalloc( (void **)&devStates, num*sizeof(curandState) );
struct test *results = (struct test*)malloc(num*sizeof(struct test));
struct test *to_device;
cudaMalloc ( (void **)&to_device, num*sizeof(to_device));
setup_kernel<<<num, 1>>>(devStates);
fill_mat<<<num,1>>>(to_device, devStates);
cudaMemcpy(results,to_device,num*sizeof(struct test),cudaMemcpyDeviceToHost);
for(int i=0;i<num;i++)
cout<<results[i].value1<<endl;
cout<<results[i].value2<<endl;
return 0;
I need also that at each call of rand() I get a different random number (so there may be some error in the passage of the B state).
Unfortunately the code that I have put doesn’t work, it give a lot of zeros for for the results.
Could somebody help me to correct this code please?
