Porting OV2718+ISP Camera driver from JetPack 3.2 to JetPack 4.2.2
We have developed 0v2718+ISP camera driver for TX2, the driver works ok on JetPack 3.2.
we have ported the driver to JetPack 4.2.2. carefully following the recommendations in the documentation. The driver probes ok, mounts the device to /dev/video0 but does not stream:
We tested with:
1、v4l2-ctl -d /dev/video0 --stream-mmap --stream-count=100 --stream-to=ov2718_video.yuv
2. Trying to debug with dmesg we got the following output:
[    1.318208] chien:ov2718_probe
[    1.318214] ov2718 30-001b: probing v4l2 sensor.
[    1.318259] chien:ov2718_parse_dt
[    1.318268] ov2718 30-001b: mclk in DT extperiph1
[    1.318401] chien:ov2718_power_get
[    1.318841] ov2718 30-001b: camera_common_regulator_get: vana
[    1.318925] ov2718 30-001b: camera_common_regulator_get: vif
[    1.318997] ov2718 30-001b: camera_common_regulator_get: vdig
[    1.319069] ov2718 30-001b: camera_common_parse_ports: port 0 num of lanes 2
[    1.319087] ov2718 30-001b: parsing for mode0 props
[    1.319106] ov2718 30-001b: sensor_common_parse_signal_props: use default phy mode DPHY
[    1.319135] ov2718 30-001b: ov2718_probe: name ov2718_a
[    1.319140] ov2718 30-001b: camera_common_create_debugfs ov2718_a
[    1.319155] ov2718 30-001b: tegracam sensor driver:ov2718_v2.0.6
[    1.319159] ov2718 30-001b: ov2718_board_setup++
[    1.319162] chien:ov2718_board_setup
[    1.319164] chien:ov2718_eeprom_device_init
[    1.319184] ov2718 30-001b: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[    1.319636] ov2718 30-001b: ov2718_power_on: power on
[    1.319639] chien:ov2718_power_on
[    1.331248] chien:ov2718_read_eeprom
[    1.331251] chien:ov2718_otp_setup
[    1.331254] chien:ov2718_fuse_id_setup
[    1.331259] ov2718 30-001b: ov2718_power_off: power off
[    1.331262] chien:ov2718_power_off
[    1.333660] ov2718 30-001b: camera_common_mclk_disable: disable MCLK
[    1.333802] chien:ov2718_debugfs_create
[    1.333819] ov2718,mode=0
[    1.333838] ov2718 30-001b: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[    1.334283] ov2718 30-001b: camera_common_dpd_disable: csi 0
[    1.334287] ov2718 30-001b: ov2718_power_on: power on
[    1.334290] chien:ov2718_power_on
[    1.398247] ov2718,isp id=0x7160,err=0
[    2.708694] ov2718,sensor id=0x0,err=-121
[    2.708698] ov2718 slave sensor init start:len=1834
[    2.709069] ov2718 30-001b: ov2718_write_reg: i2c write failed, 0x3000 = 2
[    2.709075] ov2718 sensor init end
[    2.710121] ov2718 30-001b: Detected ov2718 sensor
[    2.710190] chien:ov2718_probe
[    2.710194] ov2718 31-001b: probing v4l2 sensor.
[    2.710254] chien:ov2718_parse_dt
[    2.710265] ov2718 31-001b: mclk in DT extperiph2
[    2.710452] chien:ov2718_power_get
[    2.710892] ov2718 31-001b: camera_common_regulator_get: vana
[    2.710969] ov2718 31-001b: camera_common_regulator_get: vif
[    2.711048] ov2718 31-001b: camera_common_regulator_get: vdig
[    2.711126] ov2718 31-001b: camera_common_parse_ports: port 1 num of lanes 2
[    2.711144] ov2718 31-001b: parsing for mode0 props
[    2.711163] ov2718 31-001b: sensor_common_parse_signal_props: use default phy mode DPHY
[    2.711222] ov2718 31-001b: ov2718_probe: name ov2718_b
[    2.711226] ov2718 31-001b: camera_common_create_debugfs ov2718_b
[    2.711241] ov2718 31-001b: tegracam sensor driver:ov2718_v2.0.6
[    2.711246] ov2718 31-001b: ov2718_board_setup++
[    2.711249] chien:ov2718_board_setup
[    2.711251] chien:ov2718_eeprom_device_init
[    2.711269] ov2718 31-001b: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[    2.711719] ov2718 31-001b: ov2718_power_on: power on
[    2.711722] chien:ov2718_power_on
[    2.717878] chien:ov2718_read_eeprom
[    2.717881] chien:ov2718_otp_setup
[    2.717883] chien:ov2718_fuse_id_setup
[    2.717888] ov2718 31-001b: ov2718_power_off: power off
[    2.717890] chien:ov2718_power_off
[    2.720015] ov2718 31-001b: camera_common_mclk_disable: disable MCLK
[    2.720150] chien:ov2718_debugfs_create
[    2.720164] ov2718,mode=0
[    2.720184] ov2718 31-001b: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[    2.720597] ov2718 31-001b: camera_common_dpd_disable: csi 1
[    2.720601] ov2718 31-001b: ov2718_power_on: power on
[    2.720604] chien:ov2718_power_on
[    2.778077] ov2718,isp id=0x7160,err=0
[    3.690011] ov2718,sensor id=0x2770,err=0
[    3.690015] ov2718 slave sensor init start:len=1834
[    4.295437] ov2718 sensor init end
[    4.296443] ov2718 31-001b: Detected ov2718 sensor
[    4.868031] tegra-vi4 15700000.vi: parsing node /i2c@3180000/pca9543@70/i2c@0/ov2718_a@1b
[    4.868037] tegra-vi4 15700000.vi: handling endpoint /i2c@3180000/pca9543@70/i2c@0/ov2718_a@1b/ports/port@0/endpoint
[    4.868137] tegra-vi4 15700000.vi: subdev ov2718 30-001b bound
[    4.868147] tegra-vi4 15700000.vi: media_gobj_create id 4: entity 'ov2718 30-001b'
[    4.868151] tegra-vi4 15700000.vi: media_gobj_create id 5: source pad 'ov2718 30-001b':0
[    4.868309] tegra-vi4 15700000.vi: creating links for entity ov2718 30-001b
[    4.868313] tegra-vi4 15700000.vi: processing endpoint /i2c@3180000/pca9543@70/i2c@0/ov2718_a@1b/ports/port@0/endpoint
[    4.868330] tegra-vi4 15700000.vi: creating ov2718 30-001b:0 -> 150c0000.nvcsi--2:0 link
[    4.868424] ov2718 30-001b: camera_common_g_fmt++
[    4.869056] tegra-vi4 15700000.vi: parsing node /i2c@3180000/pca9543@70/i2c@1/ov2718_b@1b
[    4.869062] tegra-vi4 15700000.vi: handling endpoint /i2c@3180000/pca9543@70/i2c@1/ov2718_b@1b/ports/port@0/endpoint
[    4.869118] tegra-vi4 15700000.vi: subdev ov2718 31-001b bound
[    4.869123] tegra-vi4 15700000.vi: media_gobj_create id 21: entity 'ov2718 31-001b'
[    4.869127] tegra-vi4 15700000.vi: media_gobj_create id 22: source pad 'ov2718 31-001b':0
[    4.869329] tegra-vi4 15700000.vi: creating links for entity ov2718 31-001b
[    4.869333] tegra-vi4 15700000.vi: processing endpoint /i2c@3180000/pca9543@70/i2c@1/ov2718_b@1b/ports/port@0/endpoint
[    4.869350] tegra-vi4 15700000.vi: creating ov2718 31-001b:0 -> 150c0000.nvcsi--1:0 link
[    4.869410] ov2718 31-001b: camera_common_g_fmt++
[    6.610086] ov2718 30-001b: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[    6.610362] ov2718 30-001b: camera_common_dpd_disable: csi 0
[    6.610366] ov2718 30-001b: ov2718_power_on: power on
[    6.610368] chien:ov2718_power_on
[    6.618222] ov2718 30-001b: ov2718_power_off: power off
[    6.618225] chien:ov2718_power_off
[    6.620318] ov2718 30-001b: camera_common_dpd_enable: csi 0
[    6.620322] ov2718 30-001b: camera_common_mclk_disable: disable MCLK
[    6.622037] chien:ov2718_open
[    6.622044] ov2718 31-001b: ov2718_open:
[    6.624617] ov2718 31-001b: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[    6.628762] ov2718 31-001b: camera_common_dpd_disable: csi 1
[    6.628768] ov2718 31-001b: ov2718_power_on: power on
[    6.628770] chien:ov2718_power_on
[    6.635196] ov2718 31-001b: ov2718_power_off: power off
[    6.635201] chien:ov2718_power_off
[    6.637452] chien:ov2718_open
[    6.637465] ov2718 30-001b: ov2718_open:
[    6.638515] ov2718 31-001b: camera_common_dpd_enable: csi 1
[    6.638521] ov2718 31-001b: camera_common_mclk_disable: disable MCLK
[  190.061851] ov2718 30-001b: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[  190.062139] ov2718 30-001b: camera_common_dpd_disable: csi 0
[  190.062142] ov2718 30-001b: ov2718_power_on: power on
[  190.062144] chien:ov2718_power_on
[  190.068378] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_enable
[  190.069555] nvcsi 150c0000.nvcsi: settle time reading from props
[  190.069560] nvcsi 150c0000.nvcsi: csi_port: 0
[  190.069708] nvcsi 150c0000.nvcsi: settle time reading from props
[  190.069711] nvcsi 150c0000.nvcsi: csi_port: 1
[  190.074040] vb2_common_vm_open: ffffffc1dd07b3c8, refcount: 1, vma: 7fa8f87000-7fa937c000
[  190.074045] vb2_dc_mmap: mapped dma addr 0xff400000 at 0x7fa8f87000, size 4149248
[  190.074238] vb2_common_vm_open: ffffffc1d55cfbc8, refcount: 1, vma: 7fa8b92000-7fa8f87000
[  190.074240] vb2_dc_mmap: mapped dma addr 0xff000000 at 0x7fa8b92000, size 4149248
[  190.074408] vb2_common_vm_open: ffffffc1c21e08c8, refcount: 1, vma: 7fa879d000-7fa8b92000
[  190.074410] vb2_dc_mmap: mapped dma addr 0xfec00000 at 0x7fa879d000, size 4149248
[  190.074583] vb2_common_vm_open: ffffffc1e4c91d48, refcount: 1, vma: 7fa83a8000-7fa879d000
[  190.074585] vb2_dc_mmap: mapped dma addr 0xfe800000 at 0x7fa83a8000, size 4149248
[  190.076037] tegra-vi4 15700000.vi: Create Surface with imgW=1920, imgH=1080, memFmt=203
[  190.077586] nvcsi 150c0000.nvcsi: csi4_start_streaming port_idx=0, lanes=2
[  190.077592] nvcsi 150c0000.nvcsi: csi4_stream_init
[  190.077604] nvcsi 150c0000.nvcsi: csi4_stream_config
[  190.077615] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
[  190.077620] nvcsi 150c0000.nvcsi: settle time reading from props
[  190.077625] nvcsi 150c0000.nvcsi: discontinuous_clk = 0 reading from props
[  190.077628] nvcsi 150c0000.nvcsi: settle time reading from props
[  190.077632] nvcsi 150c0000.nvcsi: csi4_phy_config
[  190.077639] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
[  190.077647] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 72
[  190.077651] nvcsi 150c0000.nvcsi: cil_settingtime was autocalculated
[  190.077655] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 29
[  190.077667] ov2718 30-001b: v4l2sd_stream++ enable 1
[  190.077671] chien:ov2718_set_mode
[  190.077675] chien:ov2718_start_streaming
[  190.279590] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[  190.279698] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[  190.280889] nvcsi 150c0000.nvcsi: csi4_stop_streaming port_idx=0, lanes=2
[  190.280909] nvcsi 150c0000.nvcsi: settle time reading from props
[  190.280930] nvcsi 150c0000.nvcsi: discontinuous_clk = 0 reading from props
[  190.280947] nvcsi 150c0000.nvcsi: settle time reading from props
[  190.280961] nvcsi 150c0000.nvcsi: csi4_phy_config
[  190.280982] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000002
[  190.281004] nvcsi 150c0000.nvcsi: csi4_stream_check_status
[  190.281038] nvcsi 150c0000.nvcsi: csi4_cil_check_status 397
[  190.281059] nvcsi 150c0000.nvcsi: csi4_start_streaming port_idx=0, lanes=2
[  190.281074] nvcsi 150c0000.nvcsi: csi4_stream_init
[  190.281099] nvcsi 150c0000.nvcsi: csi4_stream_config
[  190.281124] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
[  190.281136] nvcsi 150c0000.nvcsi: settle time reading from props
[  190.281149] nvcsi 150c0000.nvcsi: discontinuous_clk = 0 reading from props
[  190.281160] nvcsi 150c0000.nvcsi: settle time reading from props
[  190.281172] nvcsi 150c0000.nvcsi: csi4_phy_config
[  190.281191] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
[  190.281213] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 72
[  190.281228] nvcsi 150c0000.nvcsi: cil_settingtime was autocalculated
[  190.281242] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 29
[  190.282233] tegra-vi4 15700000.vi: Create Surface with imgW=1920, imgH=1080, memFmt=203
[  190.282284] video4linux video0: free_ring_buffers: capture init latency is 207 ms
[  190.483758] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
3、Our device tree for the camera has the following configuration for the mode
host1x {
		vi@15700000 {	//2路输出
			num-channels = <2>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					adas_vi_in0: endpoint {
						port-index = <0>;
						bus-width = <2>;
						remote-endpoint = <&adas_csi_out0>;
				port@1 {
					reg = <1>;
					adas_vi_in1: endpoint {
						port-index = <1>;
						bus-width = <2>;
						remote-endpoint = <&adas_csi_out1>;
		nvcsi@150c0000 {
			num-channels = <2>;
			#size-cells = <0>;
			channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						adas_csi_in0: endpoint@0 {
							port-index = <0>;
							bus-width = <2>;
							remote-endpoint = <&adas_ov2718_out0>;
					port@1 {
						reg = <1>;
						adas_csi_out0: endpoint@1 {
							remote-endpoint = <&adas_vi_in0>;
			channel@1 {
				reg = <1>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						adas_csi_in1: endpoint@2 {
							port-index = <1>;
							bus-width = <2>;
							remote-endpoint = <&adas_ov2718_out1>;
					port@1 {
						reg = <1>;
						adas_csi_out1: endpoint@3 {
							remote-endpoint = <&adas_vi_in1>;
	i2c@3180000 {
		pca9543@70 {
			i2c@0 {
				reg = <0x0>;
				i2c-mux,deselect-on-exit;
				#address-cells = <0x1>;
				#size-cells = <0x0>;
				ov2718_a@1b {
					compatible = "nvidia,ov2718";
					reg = <0x1b>;
					devnode = "video0";
					physical_w = "6.534";
					physical_h = "5.724";
					avdd-reg = "vana";
					iovdd-reg = "vif";
					dvdd-reg = "vdig";
					vertical-flip = "true";
					mode0 { //OV5693_MODE_1280X720
						mclk_khz = "24000";
						num_lanes = "2";
						discontinuous_clk = "no";
						dpcm_enable = "false";
						cil_settletime = "0";
						active_w = "1920";
						active_h = "1080";
						pixel_t = "yuv_uyvy16";
						readout_orientation = "90";
						line_length = "1936";
						inherent_gain = "1";
						mclk_multiplier = "3";
						pix_clk_hz = "72000000";
						gain_factor = "10";
						min_gain_val = "0"; /* 0dB */
						max_gain_val = "480"; /* 48dB */
						step_gain_val = "3"; /* 0.3 */
						default_gain ="0";
						framerate_factor = "1000000";
						min_framerate = "1500000"; /* 1.5 */
						max_framerate = "30000000"; /* 30 */
						step_framerate = "1";
						default_framerate = "30000000";
						exposure_factor = "1000000";
						min_exp_time = "30"; /* us */
						max_exp_time = "660000"; /* us */
						step_exp_time = "1";
						default_exp_time = "33334";/* us */
					ports {
						#size-cells = <0>;
						port@0 {
							reg = <0>;
							adas_ov2718_out0: endpoint {
								port-index = <0>;
								bus-width = <2>;
								remote-endpoint = <&adas_csi_in0>;
			i2c@1 {
				reg = <0x1>;
				ov2718_b@1b {
					reg = <0x1b>;
					devnode = "video1";
					avdd-reg = "vana";
					iovdd-reg = "vif";
					dvdd-reg = "vdig";
						mclk_khz = "24000";
						num_lanes = "2";
						tegra_sinterface = "serial_b";
						active_w = "1920";
						active_h = "1080";
						mclk_multiplier = "5";
						gain_factor = "10";
						default_gain ="0";
					ports {
						#size-cells = <0>;
						port@0 {
							reg = <0>;
							adas_ov2718_out1: endpoint {
								port-index = <1>;
								bus-width = <2>;
								remote-endpoint = <&adas_csi_in1>;
Any information from trace log?
https://elinux.org/Jetson_TX2_Camera_BringUp#Steps_to_enable_more_debug_messages
the trace log:
[code]# tracer: nop
entries-in-buffer/entries-written: 2198/2198 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
vi-output, ov27-7409 [000] … 190.931334: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [000] … 190.931365: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 190.950898: rtos_queue_send_from_isr_failed: tstamp:6334488469 queue:0x0b4a7258
kworker/3:3-4237 [003] … 190.950900: rtos_queue_send_from_isr_failed: tstamp:6334488579 queue:0x0b4aad68
kworker/3:3-4237 [003] … 190.950901: rtos_queue_send_from_isr_failed: tstamp:6334488687 queue:0x0b4ac998
kworker/3:3-4237 [003] … 190.950902: rtos_queue_send_from_isr_failed: tstamp:6334488793 queue:0x0b4ae518
kworker/3:3-4237 [003] … 190.950903: rtos_queue_send_from_isr_failed: tstamp:6334488899 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 190.950903: rtos_queue_send_from_isr_failed: tstamp:6334489003 queue:0x0b4b0098
kworker/3:3-4237 [003] … 190.950904: rtos_queue_send_from_isr_failed: tstamp:6334489108 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 190.950905: rtos_queue_send_from_isr_failed: tstamp:6334489213 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 190.950906: rtos_queue_send_failed: tstamp:6334489820 queue:0x0b4a7258
kworker/3:3-4237 [003] … 190.950907: rtos_queue_send_from_isr_failed: tstamp:6334491169 queue:0x0b4a7258
kworker/3:3-4237 [003] … 190.950908: rtos_queue_send_from_isr_failed: tstamp:6334491275 queue:0x0b4aad68
kworker/3:3-4237 [003] … 190.950908: rtos_queue_send_from_isr_failed: tstamp:6334491380 queue:0x0b4ac998
kworker/3:3-4237 [003] … 190.950909: rtos_queue_send_from_isr_failed: tstamp:6334491488 queue:0x0b4ae518
kworker/3:3-4237 [003] … 190.950909: rtos_queue_send_from_isr_failed: tstamp:6334491593 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 190.950910: rtos_queue_send_from_isr_failed: tstamp:6334491697 queue:0x0b4b0098
kworker/3:3-4237 [003] … 190.950910: rtos_queue_send_from_isr_failed: tstamp:6334491800 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 190.950911: rtos_queue_send_from_isr_failed: tstamp:6334491905 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 190.950912: rtos_queue_send_failed: tstamp:6334492333 queue:0x0b4a7258
kworker/3:3-4237 [003] … 190.950912: rtos_queue_send_from_isr_failed: tstamp:6334495129 queue:0x0b4a7258
kworker/3:3-4237 [003] … 190.950913: rtos_queue_send_from_isr_failed: tstamp:6334495235 queue:0x0b4aad68
kworker/3:3-4237 [003] … 190.950914: rtos_queue_send_from_isr_failed: tstamp:6334495343 queue:0x0b4ac998
kworker/3:3-4237 [003] … 190.950914: rtos_queue_send_from_isr_failed: tstamp:6334495449 queue:0x0b4ae518
kworker/3:3-4237 [003] … 190.950915: rtos_queue_send_from_isr_failed: tstamp:6334495553 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 190.950915: rtos_queue_send_from_isr_failed: tstamp:6334495658 queue:0x0b4b0098
kworker/3:3-4237 [003] … 190.950916: rtos_queue_send_from_isr_failed: tstamp:6334495763 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 190.950916: rtos_queue_send_from_isr_failed: tstamp:6334495868 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 190.950917: rtos_queue_send_failed: tstamp:6334496300 queue:0x0b4a7258
kworker/3:3-4237 [003] … 190.950918: rtos_queue_send_from_isr_failed: tstamp:6334497437 queue:0x0b4a7258
kworker/3:3-4237 [003] … 190.950918: rtos_queue_send_from_isr_failed: tstamp:6334497543 queue:0x0b4aad68
kworker/3:3-4237 [003] … 190.950919: rtos_queue_send_from_isr_failed: tstamp:6334497650 queue:0x0b4ac998
kworker/3:3-4237 [003] … 190.950919: rtos_queue_send_from_isr_failed: tstamp:6334497756 queue:0x0b4ae518
kworker/3:3-4237 [003] … 190.950920: rtos_queue_send_from_isr_failed: tstamp:6334497861 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 190.950920: rtos_queue_send_from_isr_failed: tstamp:6334497967 queue:0x0b4b0098
kworker/3:3-4237 [003] … 190.950921: rtos_queue_send_from_isr_failed: tstamp:6334498072 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 190.950922: rtos_queue_send_from_isr_failed: tstamp:6334498177 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 190.950922: rtos_queue_send_failed: tstamp:6334499093 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.006901: rtos_queue_peek_from_isr_failed: tstamp:6336009812 queue:0x0b4b4500
vi-output, ov27-7409 [000] … 191.135285: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [000] … 191.135312: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 191.174888: rtos_queue_send_from_isr_failed: tstamp:6340862405 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.174890: rtos_queue_send_from_isr_failed: tstamp:6340862515 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.174891: rtos_queue_send_from_isr_failed: tstamp:6340862623 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.174891: rtos_queue_send_from_isr_failed: tstamp:6340862730 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.174892: rtos_queue_send_from_isr_failed: tstamp:6340862834 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.174892: rtos_queue_send_from_isr_failed: tstamp:6340862938 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.174893: rtos_queue_send_from_isr_failed: tstamp:6340863043 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.174894: rtos_queue_send_from_isr_failed: tstamp:6340863148 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.174894: rtos_queue_send_failed: tstamp:6340863739 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.174895: rtos_queue_send_from_isr_failed: tstamp:6340864854 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.174895: rtos_queue_send_from_isr_failed: tstamp:6340864972 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.174896: rtos_queue_send_from_isr_failed: tstamp:6340865080 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.174897: rtos_queue_send_from_isr_failed: tstamp:6340865186 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.174897: rtos_queue_send_from_isr_failed: tstamp:6340865291 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.174898: rtos_queue_send_from_isr_failed: tstamp:6340865396 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.174899: rtos_queue_send_from_isr_failed: tstamp:6340865503 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.174899: rtos_queue_send_from_isr_failed: tstamp:6340865606 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.174900: rtos_queue_send_failed: tstamp:6340866029 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.174901: rtos_queue_send_from_isr_failed: tstamp:6340868646 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.174901: rtos_queue_send_from_isr_failed: tstamp:6340868764 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.174902: rtos_queue_send_from_isr_failed: tstamp:6340868869 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.174902: rtos_queue_send_from_isr_failed: tstamp:6340868975 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.174903: rtos_queue_send_from_isr_failed: tstamp:6340869080 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.174904: rtos_queue_send_from_isr_failed: tstamp:6340869185 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.174904: rtos_queue_send_from_isr_failed: tstamp:6340869290 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.174905: rtos_queue_send_from_isr_failed: tstamp:6340869395 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.174905: rtos_queue_send_failed: tstamp:6340869876 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.174906: rtos_queue_send_from_isr_failed: tstamp:6340870925 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.174906: rtos_queue_send_from_isr_failed: tstamp:6340871041 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.174907: rtos_queue_send_from_isr_failed: tstamp:6340871148 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.174908: rtos_queue_send_from_isr_failed: tstamp:6340871255 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.174908: rtos_queue_send_from_isr_failed: tstamp:6340871360 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.174909: rtos_queue_send_from_isr_failed: tstamp:6340871465 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.174910: rtos_queue_send_from_isr_failed: tstamp:6340871570 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.174910: rtos_queue_send_from_isr_failed: tstamp:6340871675 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.174911: rtos_queue_send_failed: tstamp:6340872593 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.174911: rtos_queue_peek_from_isr_failed: tstamp:6341009801 queue:0x0b4b4500
vi-output, ov27-7409 [003] … 191.339272: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [003] … 191.339298: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 191.342881: rtos_queue_peek_from_isr_failed: tstamp:6346009804 queue:0x0b4b4500
kworker/3:3-4237 [003] … 191.342882: rtos_queue_send_from_isr_failed: tstamp:6347236870 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.342883: rtos_queue_send_from_isr_failed: tstamp:6347236981 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.342884: rtos_queue_send_from_isr_failed: tstamp:6347237089 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.342884: rtos_queue_send_from_isr_failed: tstamp:6347237195 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.342885: rtos_queue_send_from_isr_failed: tstamp:6347237300 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.342886: rtos_queue_send_from_isr_failed: tstamp:6347237406 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.342886: rtos_queue_send_from_isr_failed: tstamp:6347237510 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.342887: rtos_queue_send_from_isr_failed: tstamp:6347237615 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.342887: rtos_queue_send_failed: tstamp:6347238231 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.342888: rtos_queue_send_from_isr_failed: tstamp:6347239669 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.342889: rtos_queue_send_from_isr_failed: tstamp:6347239776 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.342889: rtos_queue_send_from_isr_failed: tstamp:6347239882 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.342890: rtos_queue_send_from_isr_failed: tstamp:6347239989 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.342890: rtos_queue_send_from_isr_failed: tstamp:6347240093 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.342891: rtos_queue_send_from_isr_failed: tstamp:6347240198 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.342892: rtos_queue_send_from_isr_failed: tstamp:6347240303 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.342892: rtos_queue_send_from_isr_failed: tstamp:6347240407 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.342893: rtos_queue_send_failed: tstamp:6347240832 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.342893: rtos_queue_send_from_isr_failed: tstamp:6347243448 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.342894: rtos_queue_send_from_isr_failed: tstamp:6347243554 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.342894: rtos_queue_send_from_isr_failed: tstamp:6347243659 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.342895: rtos_queue_send_from_isr_failed: tstamp:6347243766 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.342896: rtos_queue_send_from_isr_failed: tstamp:6347243871 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.342896: rtos_queue_send_from_isr_failed: tstamp:6347243974 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.342897: rtos_queue_send_from_isr_failed: tstamp:6347244079 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.342898: rtos_queue_send_from_isr_failed: tstamp:6347244192 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.342898: rtos_queue_send_failed: tstamp:6347244660 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.342899: rtos_queue_send_from_isr_failed: tstamp:6347245651 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.342900: rtos_queue_send_from_isr_failed: tstamp:6347245761 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.342900: rtos_queue_send_from_isr_failed: tstamp:6347245869 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.342901: rtos_queue_send_from_isr_failed: tstamp:6347245987 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.342901: rtos_queue_send_from_isr_failed: tstamp:6347246094 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.342902: rtos_queue_send_from_isr_failed: tstamp:6347246202 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.342903: rtos_queue_send_from_isr_failed: tstamp:6347246310 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.342903: rtos_queue_send_from_isr_failed: tstamp:6347246416 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.342904: rtos_queue_send_failed: tstamp:6347247250 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.510868: rtos_queue_peek_from_isr_failed: tstamp:6351009814 queue:0x0b4b4500
vi-output, ov27-7409 [003] … 191.543239: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [003] … 191.543265: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 191.566861: rtos_queue_send_from_isr_failed: tstamp:6353611407 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.566862: rtos_queue_send_from_isr_failed: tstamp:6353611517 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.566863: rtos_queue_send_from_isr_failed: tstamp:6353611625 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.566863: rtos_queue_send_from_isr_failed: tstamp:6353611731 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.566864: rtos_queue_send_from_isr_failed: tstamp:6353611848 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.566865: rtos_queue_send_from_isr_failed: tstamp:6353611953 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.566865: rtos_queue_send_from_isr_failed: tstamp:6353612057 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.566866: rtos_queue_send_from_isr_failed: tstamp:6353612162 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.566867: rtos_queue_send_failed: tstamp:6353612787 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.566867: rtos_queue_send_from_isr_failed: tstamp:6353613741 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.566868: rtos_queue_send_from_isr_failed: tstamp:6353613854 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.566868: rtos_queue_send_from_isr_failed: tstamp:6353613963 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.566869: rtos_queue_send_from_isr_failed: tstamp:6353614073 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.566870: rtos_queue_send_from_isr_failed: tstamp:6353614181 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.566870: rtos_queue_send_from_isr_failed: tstamp:6353614288 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.566871: rtos_queue_send_from_isr_failed: tstamp:6353614396 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.566871: rtos_queue_send_from_isr_failed: tstamp:6353614508 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.566872: rtos_queue_send_failed: tstamp:6353614891 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.566872: rtos_queue_send_from_isr_failed: tstamp:6353617376 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.566873: rtos_queue_send_from_isr_failed: tstamp:6353617491 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.566874: rtos_queue_send_from_isr_failed: tstamp:6353617599 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.566874: rtos_queue_send_from_isr_failed: tstamp:6353617705 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.566875: rtos_queue_send_from_isr_failed: tstamp:6353617810 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.566875: rtos_queue_send_from_isr_failed: tstamp:6353617915 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.566876: rtos_queue_send_from_isr_failed: tstamp:6353618023 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.566877: rtos_queue_send_from_isr_failed: tstamp:6353618128 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.566877: rtos_queue_send_failed: tstamp:6353618580 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.566879: rtos_queue_send_from_isr_failed: tstamp:6353619561 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.566879: rtos_queue_send_from_isr_failed: tstamp:6353619671 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.566880: rtos_queue_send_from_isr_failed: tstamp:6353619776 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.566881: rtos_queue_send_from_isr_failed: tstamp:6353619882 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.566881: rtos_queue_send_from_isr_failed: tstamp:6353619987 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.566882: rtos_queue_send_from_isr_failed: tstamp:6353620091 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.566883: rtos_queue_send_from_isr_failed: tstamp:6353620195 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.566883: rtos_queue_send_from_isr_failed: tstamp:6353620301 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.566884: rtos_queue_send_failed: tstamp:6353621218 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.622867: rtos_queue_peek_from_isr_failed: tstamp:6356009829 queue:0x0b4b4500
vi-output, ov27-7409 [004] … 191.747237: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [004] … 191.747264: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 191.790854: rtos_queue_send_from_isr_failed: tstamp:6359986032 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.790855: rtos_queue_send_from_isr_failed: tstamp:6359986141 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.790856: rtos_queue_send_from_isr_failed: tstamp:6359986247 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.790857: rtos_queue_send_from_isr_failed: tstamp:6359986353 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.790858: rtos_queue_send_from_isr_failed: tstamp:6359986458 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.790858: rtos_queue_send_from_isr_failed: tstamp:6359986563 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.790859: rtos_queue_send_from_isr_failed: tstamp:6359986668 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.790859: rtos_queue_send_from_isr_failed: tstamp:6359986772 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.790860: rtos_queue_send_failed: tstamp:6359987370 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.790861: rtos_queue_send_from_isr_failed: tstamp:6359988337 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.790861: rtos_queue_send_from_isr_failed: tstamp:6359988446 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.790862: rtos_queue_send_from_isr_failed: tstamp:6359988551 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.790863: rtos_queue_send_from_isr_failed: tstamp:6359988657 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.790863: rtos_queue_send_from_isr_failed: tstamp:6359988761 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.790864: rtos_queue_send_from_isr_failed: tstamp:6359988866 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.790865: rtos_queue_send_from_isr_failed: tstamp:6359988992 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.790865: rtos_queue_send_from_isr_failed: tstamp:6359989092 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.790866: rtos_queue_send_failed: tstamp:6359989535 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.790866: rtos_queue_send_from_isr_failed: tstamp:6359992109 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.790867: rtos_queue_send_from_isr_failed: tstamp:6359992217 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.790868: rtos_queue_send_from_isr_failed: tstamp:6359992323 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.790868: rtos_queue_send_from_isr_failed: tstamp:6359992428 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.790869: rtos_queue_send_from_isr_failed: tstamp:6359992533 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.790870: rtos_queue_send_from_isr_failed: tstamp:6359992638 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.790870: rtos_queue_send_from_isr_failed: tstamp:6359992743 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.790871: rtos_queue_send_from_isr_failed: tstamp:6359992847 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.790871: rtos_queue_send_failed: tstamp:6359993279 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.790872: rtos_queue_send_from_isr_failed: tstamp:6359994220 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.790872: rtos_queue_send_from_isr_failed: tstamp:6359994333 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.790873: rtos_queue_send_from_isr_failed: tstamp:6359994442 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.790874: rtos_queue_send_from_isr_failed: tstamp:6359994552 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.790875: rtos_queue_send_from_isr_failed: tstamp:6359994661 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.790875: rtos_queue_send_from_isr_failed: tstamp:6359994769 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.790876: rtos_queue_send_from_isr_failed: tstamp:6359994876 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.790876: rtos_queue_send_from_isr_failed: tstamp:6359994976 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.790877: rtos_queue_send_failed: tstamp:6359995952 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.790878: rtos_queue_peek_from_isr_failed: tstamp:6361009829 queue:0x0b4b4500
vi-output, ov27-7409 [004] … 191.951217: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [004] … 191.951243: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 191.958849: rtos_queue_peek_from_isr_failed: tstamp:6366009833 queue:0x0b4b4500
kworker/3:3-4237 [003] … 191.958851: rtos_queue_send_from_isr_failed: tstamp:6366360620 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.958852: rtos_queue_send_from_isr_failed: tstamp:6366360730 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.958852: rtos_queue_send_from_isr_failed: tstamp:6366360838 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.958853: rtos_queue_send_from_isr_failed: tstamp:6366360944 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.958854: rtos_queue_send_from_isr_failed: tstamp:6366361049 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.958854: rtos_queue_send_from_isr_failed: tstamp:6366361154 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.958855: rtos_queue_send_from_isr_failed: tstamp:6366361259 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.958855: rtos_queue_send_from_isr_failed: tstamp:6366361363 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.958856: rtos_queue_send_failed: tstamp:6366361976 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.958857: rtos_queue_send_from_isr_failed: tstamp:6366362958 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.958858: rtos_queue_send_from_isr_failed: tstamp:6366363077 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.958858: rtos_queue_send_from_isr_failed: tstamp:6366363183 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.958859: rtos_queue_send_from_isr_failed: tstamp:6366363296 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.958859: rtos_queue_send_from_isr_failed: tstamp:6366363400 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.958860: rtos_queue_send_from_isr_failed: tstamp:6366363511 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.958861: rtos_queue_send_from_isr_failed: tstamp:6366363615 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.958861: rtos_queue_send_from_isr_failed: tstamp:6366363719 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.958862: rtos_queue_send_failed: tstamp:6366364143 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.958862: rtos_queue_send_from_isr_failed: tstamp:6366366696 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.958863: rtos_queue_send_from_isr_failed: tstamp:6366366802 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.958863: rtos_queue_send_from_isr_failed: tstamp:6366366907 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.958864: rtos_queue_send_from_isr_failed: tstamp:6366367015 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.958865: rtos_queue_send_from_isr_failed: tstamp:6366367120 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.958865: rtos_queue_send_from_isr_failed: tstamp:6366367225 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.958866: rtos_queue_send_from_isr_failed: tstamp:6366367330 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.958866: rtos_queue_send_from_isr_failed: tstamp:6366367435 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.958867: rtos_queue_send_failed: tstamp:6366367864 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.958868: rtos_queue_send_from_isr_failed: tstamp:6366368850 queue:0x0b4a7258
kworker/3:3-4237 [003] … 191.958868: rtos_queue_send_from_isr_failed: tstamp:6366368960 queue:0x0b4aad68
kworker/3:3-4237 [003] … 191.958869: rtos_queue_send_from_isr_failed: tstamp:6366369069 queue:0x0b4ac998
kworker/3:3-4237 [003] … 191.958869: rtos_queue_send_from_isr_failed: tstamp:6366369179 queue:0x0b4ae518
kworker/3:3-4237 [003] … 191.958870: rtos_queue_send_from_isr_failed: tstamp:6366369287 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 191.958871: rtos_queue_send_from_isr_failed: tstamp:6366369394 queue:0x0b4b0098
kworker/3:3-4237 [003] … 191.958871: rtos_queue_send_from_isr_failed: tstamp:6366369502 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 191.958872: rtos_queue_send_from_isr_failed: tstamp:6366369610 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 191.958872: rtos_queue_send_failed: tstamp:6366370490 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.126831: rtos_queue_peek_from_isr_failed: tstamp:6371009839 queue:0x0b4b4500
vi-output, ov27-7409 [004] … 192.155204: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [004] … 192.155229: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 192.182833: rtos_queue_send_from_isr_failed: tstamp:6372735145 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.182834: rtos_queue_send_from_isr_failed: tstamp:6372735256 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.182835: rtos_queue_send_from_isr_failed: tstamp:6372735367 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.182835: rtos_queue_send_from_isr_failed: tstamp:6372735474 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.182836: rtos_queue_send_from_isr_failed: tstamp:6372735586 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.182836: rtos_queue_send_from_isr_failed: tstamp:6372735691 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.182837: rtos_queue_send_from_isr_failed: tstamp:6372735795 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.182838: rtos_queue_send_from_isr_failed: tstamp:6372735899 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.182838: rtos_queue_send_failed: tstamp:6372736493 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.182839: rtos_queue_send_from_isr_failed: tstamp:6372737496 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.182840: rtos_queue_send_from_isr_failed: tstamp:6372737617 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.182840: rtos_queue_send_from_isr_failed: tstamp:6372737725 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.182841: rtos_queue_send_from_isr_failed: tstamp:6372737832 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.182841: rtos_queue_send_from_isr_failed: tstamp:6372737940 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.182842: rtos_queue_send_from_isr_failed: tstamp:6372738046 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.182842: rtos_queue_send_from_isr_failed: tstamp:6372738154 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.182843: rtos_queue_send_from_isr_failed: tstamp:6372738260 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.182844: rtos_queue_send_failed: tstamp:6372738606 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.182844: rtos_queue_send_from_isr_failed: tstamp:6372741113 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.182845: rtos_queue_send_from_isr_failed: tstamp:6372741227 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.182845: rtos_queue_send_from_isr_failed: tstamp:6372741335 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.182846: rtos_queue_send_from_isr_failed: tstamp:6372741441 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.182847: rtos_queue_send_from_isr_failed: tstamp:6372741546 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.182847: rtos_queue_send_from_isr_failed: tstamp:6372741651 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.182848: rtos_queue_send_from_isr_failed: tstamp:6372741756 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.182848: rtos_queue_send_from_isr_failed: tstamp:6372741861 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.182849: rtos_queue_send_failed: tstamp:6372742290 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.182850: rtos_queue_send_from_isr_failed: tstamp:6372743348 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.182850: rtos_queue_send_from_isr_failed: tstamp:6372743464 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.182851: rtos_queue_send_from_isr_failed: tstamp:6372743570 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.182851: rtos_queue_send_from_isr_failed: tstamp:6372743676 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.182852: rtos_queue_send_from_isr_failed: tstamp:6372743781 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.182853: rtos_queue_send_from_isr_failed: tstamp:6372743886 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.182853: rtos_queue_send_from_isr_failed: tstamp:6372743990 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.182854: rtos_queue_send_from_isr_failed: tstamp:6372744094 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.182854: rtos_queue_send_failed: tstamp:6372745030 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.294822: rtos_queue_peek_from_isr_failed: tstamp:6376009856 queue:0x0b4b4500
vi-output, ov27-7409 [004] … 192.359208: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [004] … 192.359234: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 192.406818: rtos_queue_send_from_isr_failed: tstamp:6379109801 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.406819: rtos_queue_send_from_isr_failed: tstamp:6379109911 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.406820: rtos_queue_send_from_isr_failed: tstamp:6379110019 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.406820: rtos_queue_send_from_isr_failed: tstamp:6379110126 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.406821: rtos_queue_send_from_isr_failed: tstamp:6379110241 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.406822: rtos_queue_send_from_isr_failed: tstamp:6379110344 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.406822: rtos_queue_send_from_isr_failed: tstamp:6379110449 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.406823: rtos_queue_send_from_isr_failed: tstamp:6379110554 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.406823: rtos_queue_send_failed: tstamp:6379111152 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.406824: rtos_queue_send_from_isr_failed: tstamp:6379112341 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.406825: rtos_queue_send_from_isr_failed: tstamp:6379112457 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.406825: rtos_queue_send_from_isr_failed: tstamp:6379112563 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.406826: rtos_queue_send_from_isr_failed: tstamp:6379112669 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.406826: rtos_queue_send_from_isr_failed: tstamp:6379112774 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.406827: rtos_queue_send_from_isr_failed: tstamp:6379112879 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.406827: rtos_queue_send_from_isr_failed: tstamp:6379112991 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.406828: rtos_queue_send_from_isr_failed: tstamp:6379113096 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.406829: rtos_queue_send_failed: tstamp:6379113521 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.406829: rtos_queue_send_from_isr_failed: tstamp:6379116042 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.406830: rtos_queue_send_from_isr_failed: tstamp:6379116157 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.406830: rtos_queue_send_from_isr_failed: tstamp:6379116264 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.406831: rtos_queue_send_from_isr_failed: tstamp:6379116370 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.406832: rtos_queue_send_from_isr_failed: tstamp:6379116475 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.406833: rtos_queue_send_from_isr_failed: tstamp:6379116580 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.406834: rtos_queue_send_from_isr_failed: tstamp:6379116684 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.406834: rtos_queue_send_from_isr_failed: tstamp:6379116787 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.406835: rtos_queue_send_failed: tstamp:6379117240 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.406835: rtos_queue_send_from_isr_failed: tstamp:6379118363 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.406836: rtos_queue_send_from_isr_failed: tstamp:6379118473 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.406837: rtos_queue_send_from_isr_failed: tstamp:6379118579 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.406837: rtos_queue_send_from_isr_failed: tstamp:6379118686 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.406838: rtos_queue_send_from_isr_failed: tstamp:6379118838 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.406838: rtos_queue_send_from_isr_failed: tstamp:6379118941 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.406839: rtos_queue_send_from_isr_failed: tstamp:6379119045 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.406840: rtos_queue_send_from_isr_failed: tstamp:6379119150 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.406840: rtos_queue_send_failed: tstamp:6379120129 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.462814: rtos_queue_peek_from_isr_failed: tstamp:6381009855 queue:0x0b4b4500
vi-output, ov27-7409 [004] … 192.563187: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [004] … 192.563213: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 192.574800: rtos_queue_send_from_isr_failed: tstamp:6385484494 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.574802: rtos_queue_send_from_isr_failed: tstamp:6385484604 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.574802: rtos_queue_send_from_isr_failed: tstamp:6385484712 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.574803: rtos_queue_send_from_isr_failed: tstamp:6385484818 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.574804: rtos_queue_send_from_isr_failed: tstamp:6385484923 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.574804: rtos_queue_send_from_isr_failed: tstamp:6385485028 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.574805: rtos_queue_send_from_isr_failed: tstamp:6385485133 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.574805: rtos_queue_send_from_isr_failed: tstamp:6385485237 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.574806: rtos_queue_send_failed: tstamp:6385485853 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.574807: rtos_queue_send_from_isr_failed: tstamp:6385486855 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.574807: rtos_queue_send_from_isr_failed: tstamp:6385486968 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.574808: rtos_queue_send_from_isr_failed: tstamp:6385487076 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.574808: rtos_queue_send_from_isr_failed: tstamp:6385487185 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.574809: rtos_queue_send_from_isr_failed: tstamp:6385487291 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.574809: rtos_queue_send_from_isr_failed: tstamp:6385487397 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.574810: rtos_queue_send_from_isr_failed: tstamp:6385487505 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.574811: rtos_queue_send_from_isr_failed: tstamp:6385487611 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.574811: rtos_queue_send_failed: tstamp:6385487959 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.574812: rtos_queue_send_from_isr_failed: tstamp:6385490556 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.574812: rtos_queue_send_from_isr_failed: tstamp:6385490662 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.574813: rtos_queue_send_from_isr_failed: tstamp:6385490769 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.574814: rtos_queue_send_from_isr_failed: tstamp:6385490875 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.574814: rtos_queue_send_from_isr_failed: tstamp:6385490979 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.574815: rtos_queue_send_from_isr_failed: tstamp:6385491082 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.574815: rtos_queue_send_from_isr_failed: tstamp:6385491197 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.574816: rtos_queue_send_from_isr_failed: tstamp:6385491300 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.574816: rtos_queue_send_failed: tstamp:6385491746 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.574817: rtos_queue_send_from_isr_failed: tstamp:6385492812 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.574818: rtos_queue_send_from_isr_failed: tstamp:6385492919 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.574818: rtos_queue_send_from_isr_failed: tstamp:6385493025 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.574819: rtos_queue_send_from_isr_failed: tstamp:6385493131 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.574819: rtos_queue_send_from_isr_failed: tstamp:6385493236 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.574820: rtos_queue_send_from_isr_failed: tstamp:6385493341 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.574821: rtos_queue_send_from_isr_failed: tstamp:6385493446 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.574821: rtos_queue_send_from_isr_failed: tstamp:6385493552 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.574822: rtos_queue_send_failed: tstamp:6385494526 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.630809: rtos_queue_peek_from_isr_failed: tstamp:6386009860 queue:0x0b4b4500
kworker/3:3-4237 [003] … 192.742804: rtos_queue_peek_from_isr_failed: tstamp:6391009867 queue:0x0b4b4500
vi-output, ov27-7409 [004] … 192.767170: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [004] … 192.767195: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 192.798785: rtos_queue_send_from_isr_failed: tstamp:6391859174 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.798786: rtos_queue_send_from_isr_failed: tstamp:6391859287 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.798787: rtos_queue_send_from_isr_failed: tstamp:6391859395 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.798787: rtos_queue_send_from_isr_failed: tstamp:6391859501 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.798788: rtos_queue_send_from_isr_failed: tstamp:6391859607 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.798789: rtos_queue_send_from_isr_failed: tstamp:6391859712 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.798789: rtos_queue_send_from_isr_failed: tstamp:6391859817 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.798790: rtos_queue_send_from_isr_failed: tstamp:6391859922 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.798791: rtos_queue_send_failed: tstamp:6391860524 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.798791: rtos_queue_send_from_isr_failed: tstamp:6391861526 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.798792: rtos_queue_send_from_isr_failed: tstamp:6391861636 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.798793: rtos_queue_send_from_isr_failed: tstamp:6391861744 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.798793: rtos_queue_send_from_isr_failed: tstamp:6391861854 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.798794: rtos_queue_send_from_isr_failed: tstamp:6391861962 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.798794: rtos_queue_send_from_isr_failed: tstamp:6391862068 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.798795: rtos_queue_send_from_isr_failed: tstamp:6391862180 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.798796: rtos_queue_send_from_isr_failed: tstamp:6391862286 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.798796: rtos_queue_send_failed: tstamp:6391862634 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.798797: rtos_queue_send_from_isr_failed: tstamp:6391865200 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.798797: rtos_queue_send_from_isr_failed: tstamp:6391865306 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.798798: rtos_queue_send_from_isr_failed: tstamp:6391865422 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.798798: rtos_queue_send_from_isr_failed: tstamp:6391865528 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.798799: rtos_queue_send_from_isr_failed: tstamp:6391865633 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.798800: rtos_queue_send_from_isr_failed: tstamp:6391865738 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.798800: rtos_queue_send_from_isr_failed: tstamp:6391865843 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.798801: rtos_queue_send_from_isr_failed: tstamp:6391865948 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.798802: rtos_queue_send_failed: tstamp:6391866377 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.798802: rtos_queue_send_from_isr_failed: tstamp:6391867354 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.798803: rtos_queue_send_from_isr_failed: tstamp:6391867465 queue:0x0b4aad68
kworker/3:3-4237 [003] … 192.798803: rtos_queue_send_from_isr_failed: tstamp:6391867573 queue:0x0b4ac998
kworker/3:3-4237 [003] … 192.798804: rtos_queue_send_from_isr_failed: tstamp:6391867682 queue:0x0b4ae518
kworker/3:3-4237 [003] … 192.798804: rtos_queue_send_from_isr_failed: tstamp:6391867789 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 192.798805: rtos_queue_send_from_isr_failed: tstamp:6391867897 queue:0x0b4b0098
kworker/3:3-4237 [003] … 192.798806: rtos_queue_send_from_isr_failed: tstamp:6391868003 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 192.798806: rtos_queue_send_from_isr_failed: tstamp:6391868111 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 192.798807: rtos_queue_send_failed: tstamp:6391869000 queue:0x0b4a7258
kworker/3:3-4237 [003] … 192.910788: rtos_queue_peek_from_isr_failed: tstamp:6396009877 queue:0x0b4b4500
vi-output, ov27-7409 [004] … 192.971162: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [004] … 192.971189: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 193.022784: rtos_queue_send_from_isr_failed: tstamp:6398233915 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.022785: rtos_queue_send_from_isr_failed: tstamp:6398234025 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.022786: rtos_queue_send_from_isr_failed: tstamp:6398234132 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.022786: rtos_queue_send_from_isr_failed: tstamp:6398234238 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.022787: rtos_queue_send_from_isr_failed: tstamp:6398234343 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.022787: rtos_queue_send_from_isr_failed: tstamp:6398234447 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.022788: rtos_queue_send_from_isr_failed: tstamp:6398234556 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.022788: rtos_queue_send_from_isr_failed: tstamp:6398234661 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.022789: rtos_queue_send_failed: tstamp:6398235255 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.022790: rtos_queue_send_from_isr_failed: tstamp:6398236239 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.022790: rtos_queue_send_from_isr_failed: tstamp:6398236358 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.022791: rtos_queue_send_from_isr_failed: tstamp:6398236466 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.022792: rtos_queue_send_from_isr_failed: tstamp:6398236575 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.022792: rtos_queue_send_from_isr_failed: tstamp:6398236681 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.022793: rtos_queue_send_from_isr_failed: tstamp:6398236787 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.022793: rtos_queue_send_from_isr_failed: tstamp:6398236895 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.022794: rtos_queue_send_from_isr_failed: tstamp:6398237001 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.022794: rtos_queue_send_failed: tstamp:6398237349 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.022795: rtos_queue_send_from_isr_failed: tstamp:6398239871 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.022796: rtos_queue_send_from_isr_failed: tstamp:6398239986 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.022796: rtos_queue_send_from_isr_failed: tstamp:6398240093 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.022797: rtos_queue_send_from_isr_failed: tstamp:6398240199 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.022797: rtos_queue_send_from_isr_failed: tstamp:6398240304 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.022798: rtos_queue_send_from_isr_failed: tstamp:6398240409 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.022799: rtos_queue_send_from_isr_failed: tstamp:6398240514 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.022799: rtos_queue_send_from_isr_failed: tstamp:6398240623 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.022800: rtos_queue_send_failed: tstamp:6398241053 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.022800: rtos_queue_send_from_isr_failed: tstamp:6398242104 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.022801: rtos_queue_send_from_isr_failed: tstamp:6398242209 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.022802: rtos_queue_send_from_isr_failed: tstamp:6398242315 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.022802: rtos_queue_send_from_isr_failed: tstamp:6398242420 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.022803: rtos_queue_send_from_isr_failed: tstamp:6398242525 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.022803: rtos_queue_send_from_isr_failed: tstamp:6398242629 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.022804: rtos_queue_send_from_isr_failed: tstamp:6398242734 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.022805: rtos_queue_send_from_isr_failed: tstamp:6398242838 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.022805: rtos_queue_send_failed: tstamp:6398243770 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.078777: rtos_queue_peek_from_isr_failed: tstamp:6401009893 queue:0x0b4b4500
vi-output, ov27-7409 [000] … 193.175158: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [000] … 193.175184: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 193.190771: rtos_queue_send_from_isr_failed: tstamp:6404608665 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.190772: rtos_queue_send_from_isr_failed: tstamp:6404608776 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.190773: rtos_queue_send_from_isr_failed: tstamp:6404608882 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.190774: rtos_queue_send_from_isr_failed: tstamp:6404608990 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.190774: rtos_queue_send_from_isr_failed: tstamp:6404609093 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.190775: rtos_queue_send_from_isr_failed: tstamp:6404609198 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.190775: rtos_queue_send_from_isr_failed: tstamp:6404609302 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.190776: rtos_queue_send_from_isr_failed: tstamp:6404609406 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.190777: rtos_queue_send_failed: tstamp:6404610014 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.190777: rtos_queue_send_from_isr_failed: tstamp:6404611016 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.190778: rtos_queue_send_from_isr_failed: tstamp:6404611150 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.190778: rtos_queue_send_from_isr_failed: tstamp:6404611260 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.190779: rtos_queue_send_from_isr_failed: tstamp:6404611370 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.190780: rtos_queue_send_from_isr_failed: tstamp:6404611478 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.190780: rtos_queue_send_from_isr_failed: tstamp:6404611584 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.190781: rtos_queue_send_from_isr_failed: tstamp:6404611692 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.190781: rtos_queue_send_from_isr_failed: tstamp:6404611798 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.190782: rtos_queue_send_failed: tstamp:6404612148 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.190783: rtos_queue_send_from_isr_failed: tstamp:6404614727 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.190784: rtos_queue_send_from_isr_failed: tstamp:6404614834 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.190785: rtos_queue_send_from_isr_failed: tstamp:6404614939 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.190785: rtos_queue_send_from_isr_failed: tstamp:6404615045 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.190786: rtos_queue_send_from_isr_failed: tstamp:6404615149 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.190787: rtos_queue_send_from_isr_failed: tstamp:6404615256 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.190787: rtos_queue_send_from_isr_failed: tstamp:6404615360 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.190788: rtos_queue_send_from_isr_failed: tstamp:6404615464 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.190788: rtos_queue_send_failed: tstamp:6404615898 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.190789: rtos_queue_send_from_isr_failed: tstamp:6404616951 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.190790: rtos_queue_send_from_isr_failed: tstamp:6404617056 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.190790: rtos_queue_send_from_isr_failed: tstamp:6404617161 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.190791: rtos_queue_send_from_isr_failed: tstamp:6404617268 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.190791: rtos_queue_send_from_isr_failed: tstamp:6404617371 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.190792: rtos_queue_send_from_isr_failed: tstamp:6404617476 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.190793: rtos_queue_send_from_isr_failed: tstamp:6404617581 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.190793: rtos_queue_send_from_isr_failed: tstamp:6404617686 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.190794: rtos_queue_send_failed: tstamp:6404618612 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.246769: rtos_queue_peek_from_isr_failed: tstamp:6406009887 queue:0x0b4b4500
vi-output, ov27-7409 [000] … 193.379216: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [000] … 193.379242: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 193.414762: rtos_queue_send_from_isr_failed: tstamp:6410985350 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.414764: rtos_queue_send_from_isr_failed: tstamp:6410985460 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.414764: rtos_queue_send_from_isr_failed: tstamp:6410985571 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.414765: rtos_queue_send_from_isr_failed: tstamp:6410985677 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.414766: rtos_queue_send_from_isr_failed: tstamp:6410985782 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.414766: rtos_queue_send_from_isr_failed: tstamp:6410985888 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.414767: rtos_queue_send_from_isr_failed: tstamp:6410985993 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.414767: rtos_queue_send_from_isr_failed: tstamp:6410986098 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.414768: rtos_queue_send_failed: tstamp:6410986699 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.414769: rtos_queue_send_from_isr_failed: tstamp:6410987757 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.414770: rtos_queue_send_from_isr_failed: tstamp:6410987863 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.414770: rtos_queue_send_from_isr_failed: tstamp:6410987975 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.414771: rtos_queue_send_from_isr_failed: tstamp:6410988081 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.414771: rtos_queue_send_from_isr_failed: tstamp:6410988186 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.414772: rtos_queue_send_from_isr_failed: tstamp:6410988291 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.414773: rtos_queue_send_from_isr_failed: tstamp:6410988395 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.414773: rtos_queue_send_from_isr_failed: tstamp:6410988498 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.414774: rtos_queue_send_failed: tstamp:6410988921 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.414774: rtos_queue_send_from_isr_failed: tstamp:6410991513 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.414775: rtos_queue_send_from_isr_failed: tstamp:6410991620 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.414775: rtos_queue_send_from_isr_failed: tstamp:6410991726 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.414776: rtos_queue_send_from_isr_failed: tstamp:6410991835 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.414777: rtos_queue_send_from_isr_failed: tstamp:6410991940 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.414777: rtos_queue_send_from_isr_failed: tstamp:6410992045 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.414778: rtos_queue_send_from_isr_failed: tstamp:6410992150 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.414778: rtos_queue_send_from_isr_failed: tstamp:6410992255 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.414779: rtos_queue_send_failed: tstamp:6410992680 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.414780: rtos_queue_send_from_isr_failed: tstamp:6410993738 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.414780: rtos_queue_send_from_isr_failed: tstamp:6410993846 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.414781: rtos_queue_send_from_isr_failed: tstamp:6410993952 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.414781: rtos_queue_send_from_isr_failed: tstamp:6410994059 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.414782: rtos_queue_send_from_isr_failed: tstamp:6410994162 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.414782: rtos_queue_send_from_isr_failed: tstamp:6410994267 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.414783: rtos_queue_send_from_isr_failed: tstamp:6410994371 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.414784: rtos_queue_send_from_isr_failed: tstamp:6410994475 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.414784: rtos_queue_send_failed: tstamp:6410995438 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.414785: rtos_queue_peek_from_isr_failed: tstamp:6411009890 queue:0x0b4b4500
kworker/3:3-4237 [003] … 193.582753: rtos_queue_peek_from_isr_failed: tstamp:6416009906 queue:0x0b4b4500
vi-output, ov27-7409 [003] … 193.583140: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [003] … 193.583166: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 193.638753: rtos_queue_send_from_isr_failed: tstamp:6417357980 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.638754: rtos_queue_send_from_isr_failed: tstamp:6417358090 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.638755: rtos_queue_send_from_isr_failed: tstamp:6417358198 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.638755: rtos_queue_send_from_isr_failed: tstamp:6417358306 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.638756: rtos_queue_send_from_isr_failed: tstamp:6417358409 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.638756: rtos_queue_send_from_isr_failed: tstamp:6417358520 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.638757: rtos_queue_send_from_isr_failed: tstamp:6417358623 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.638758: rtos_queue_send_from_isr_failed: tstamp:6417358728 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.638758: rtos_queue_send_failed: tstamp:6417359334 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.638759: rtos_queue_send_from_isr_failed: tstamp:6417360305 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.638760: rtos_queue_send_from_isr_failed: tstamp:6417360415 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.638760: rtos_queue_send_from_isr_failed: tstamp:6417360520 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.638761: rtos_queue_send_from_isr_failed: tstamp:6417360627 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.638761: rtos_queue_send_from_isr_failed: tstamp:6417360729 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.638762: rtos_queue_send_from_isr_failed: tstamp:6417360833 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.638762: rtos_queue_send_from_isr_failed: tstamp:6417360938 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.638763: rtos_queue_send_from_isr_failed: tstamp:6417361038 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.638764: rtos_queue_send_failed: tstamp:6417361495 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.638764: rtos_queue_send_from_isr_failed: tstamp:6417364007 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.638765: rtos_queue_send_from_isr_failed: tstamp:6417364115 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.638765: rtos_queue_send_from_isr_failed: tstamp:6417364220 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.638766: rtos_queue_send_from_isr_failed: tstamp:6417364327 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.638766: rtos_queue_send_from_isr_failed: tstamp:6417364431 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.638767: rtos_queue_send_from_isr_failed: tstamp:6417364536 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.638768: rtos_queue_send_from_isr_failed: tstamp:6417364642 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.638768: rtos_queue_send_from_isr_failed: tstamp:6417364746 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.638769: rtos_queue_send_failed: tstamp:6417365179 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.638770: rtos_queue_send_from_isr_failed: tstamp:6417366371 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.638770: rtos_queue_send_from_isr_failed: tstamp:6417366477 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.638771: rtos_queue_send_from_isr_failed: tstamp:6417366585 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.638771: rtos_queue_send_from_isr_failed: tstamp:6417366691 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.638772: rtos_queue_send_from_isr_failed: tstamp:6417366799 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.638773: rtos_queue_send_from_isr_failed: tstamp:6417366904 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.638773: rtos_queue_send_from_isr_failed: tstamp:6417367009 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.638774: rtos_queue_send_from_isr_failed: tstamp:6417367114 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.638774: rtos_queue_send_failed: tstamp:6417368027 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.750744: rtos_queue_peek_from_isr_failed: tstamp:6421009908 queue:0x0b4b4500
vi-output, ov27-7409 [003] … 193.787115: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov27-7409 [003] … 193.787140: tegra_channel_capture_frame: sof:-549620695332.-267015428096
kworker/3:3-4237 [003] … 193.806733: rtos_queue_send_from_isr_failed: tstamp:6423732479 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.806734: rtos_queue_send_from_isr_failed: tstamp:6423732589 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.806735: rtos_queue_send_from_isr_failed: tstamp:6423732695 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.806735: rtos_queue_send_from_isr_failed: tstamp:6423732802 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.806736: rtos_queue_send_from_isr_failed: tstamp:6423732905 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.806737: rtos_queue_send_from_isr_failed: tstamp:6423733010 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.806738: rtos_queue_send_from_isr_failed: tstamp:6423733114 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.806738: rtos_queue_send_from_isr_failed: tstamp:6423733219 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.806739: rtos_queue_send_failed: tstamp:6423733825 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.806739: rtos_queue_send_from_isr_failed: tstamp:6423734758 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.806740: rtos_queue_send_from_isr_failed: tstamp:6423734883 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.806741: rtos_queue_send_from_isr_failed: tstamp:6423734992 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.806741: rtos_queue_send_from_isr_failed: tstamp:6423735102 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.806742: rtos_queue_send_from_isr_failed: tstamp:6423735211 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.806742: rtos_queue_send_from_isr_failed: tstamp:6423735320 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.806743: rtos_queue_send_from_isr_failed: tstamp:6423735429 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.806744: rtos_queue_send_from_isr_failed: tstamp:6423735530 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.806744: rtos_queue_send_failed: tstamp:6423735988 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.806745: rtos_queue_send_from_isr_failed: tstamp:6423738526 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.806745: rtos_queue_send_from_isr_failed: tstamp:6423738633 queue:0x0b4aad68
kworker/3:3-4237 [003] … 193.806746: rtos_queue_send_from_isr_failed: tstamp:6423738739 queue:0x0b4ac998
kworker/3:3-4237 [003] … 193.806747: rtos_queue_send_from_isr_failed: tstamp:6423738845 queue:0x0b4ae518
kworker/3:3-4237 [003] … 193.806747: rtos_queue_send_from_isr_failed: tstamp:6423738949 queue:0x0b4af2d8
kworker/3:3-4237 [003] … 193.806748: rtos_queue_send_from_isr_failed: tstamp:6423739054 queue:0x0b4b0098
kworker/3:3-4237 [003] … 193.806748: rtos_queue_send_from_isr_failed: tstamp:6423739159 queue:0x0b4b0e58
kworker/3:3-4237 [003] … 193.806749: rtos_queue_send_from_isr_failed: tstamp:6423739273 queue:0x0b4b1c18
kworker/3:3-4237 [003] … 193.806749: rtos_queue_send_failed: tstamp:6423739726 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.806750: rtos_queue_send_from_isr_failed: tstamp:6423740652 queue:0x0b4a7258
kworker/3:3-4237 [003] … 193.806751: rtos_queue_send_from_isr_failed: tstamp:6423740761 queue:0x0b4aad68
The logs show didn’t get any validate data from MIPI bus. You may need to probe the confirm it.
