I have to port an old kernel driver developed for 2.6.x
If contains the following code:
memset(&pdma->cioque, 0, sizeof(struct gefspa_ioque_t));
memset(&pdma->ciobuf, 0, sizeof(struct gefspa_iobuf_t));
if (NULL == (pdma->ciobuf.maplist = (struct page **) kmalloc(pdma->maxpages * sizeof(struct page*), GFP_KERNEL))) {
return -ENOMEM;
memset(pdma->ciobuf.maplist, 0, pdma->maxpages * sizeof(struct page*));
if(NULL == (pdma->sglist = (void*) __get_dma_pages(GFP_KERNEL, __get_order(pdma->maxpages*entrysz)))) {
kfree(pdma->ciobuf.maplist);
pdma->ciobuf.maplist = NULL;
return -ENOMEM;
memset(pdma->sglist, 0, pdma->maxpages*entrysz);
pdma->sgsize = entrysz;
pdma->sgbusaddr = virt_to_bus(pdma->sglist);
I think the last line should be converted to:
pdma->sgbusaddr = dma_map_single (&pdma->board->pdev->dev, pdma->sglist, pdma->maxpages*entrysz, DMA_FROM_DEVICE);
When I load the driver (insmod) I got a kernel oops:
Unable to handle kernel NULL pointer dereference at virtual address 00000028
Also tried to use: virt_to_physical (psma->sglist)
But when DMA started I got the following kernel oops:
[ 3368.052470] arm-smmu 12000000.iommu: Unhandled context fault: iova=0xea9e8000, fsynr=0x1, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[ 3368.313623] irq 55: nobody cared (try booting with the “irqpoll” option)
I searched google and found a thread here that talks about a patch in tegra_pcie_enable_pci
https://devtalk.nvidia.com/default/topic/1002486/jetson-tx2/iommu-unhandled-context-fault-on-pci-device-dma/
Is this patch still relevant ?
I’m using last version of JetPack for TX2: 3.3
Thank you in advance,
Zvika
