I am currently developing the environment to capture an image and pose of a falling object in every two second using the extension. However, the image and the pose I got is un-synchronized, and it is capturing the pose that is few milisecond before the the timing of image.
code is something like follows.
from omni.isaac.dynamic_control import _dynamic_control
dc = _dynamic_control.acquire_dynamic_control_interface()
def _update(self, dt):
# capture every two second
if time>2.0:
# capture image
img = get_rgb_numpy()
# capture current pose of the object
body_handle = dc.get_rigid_body(prim_path)
tr = dc.get_rigid_body_pose(body_handle)
# save the output
save_img(img)
save_pose(tr)
# reset the environment and re-drop the objects
reset_and_drop_objects()
time=0
time+=dt
It seems like this problem happens since the physics engine is running independently in the different thread from the renderer. This problem does not happen when I use Python script and manually control the simulation step. However, I want to run using extension because it runs faster then the Python script.
How can I capture the pose and image exactly at the same timing??
What I have tried is the following, but I have no luck with it.
use editor.pause()
# capture every two second if time>2.0: self._editor.pause() # capture image img = get_rgb_numpy() # capture current pose of the object body_handle = dc.get_rigid_body(prim_path) tr = dc.get_rigid_body_pose(body_handle) # save the output save_img(img) save_pose(tr) self._editor.play() # reset the environment and re-drop the objects reset_and_drop_objects() time=0 time+=dt
