Pose classification with tee and msgbroker
I am have modified tha pose-classification-app
original link-
i have added tee with msgconv and msgbroker at one end and display at other end , iam getting error
0:00:19.013419359 21437 0x55c8211062e0 WARN nvinfer gstnvinfer.cpp:2420:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:19.013436682 21437 0x55c8211062e0 WARN nvinfer gstnvinfer.cpp:2420:gst_nvinfer_output_loop: error: streaming stopped, reason not-linked (-1)
ERROR from element bodypose-classification-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(2420): gst_nvinfer_output_loop (): /GstPipeline:deepstream_pose_classfication_app/GstNvInfer:bodypose-classification-nvinference-engine:
Returned, stopping playback
[NvMultiObjectTracker] De-initialized
code-
gst_bin_add_many(GST_BIN(pipeline),streammux,
nvvideoconvert_enlarge, capsFilter_enlarge, pgie, tracker, sgie, preprocess1, sgie1,
nvdslogger, nvvideoconvert_reduce, capsFilter_reduce, nvtile, nvvidconv, nvosd,queue1,queue2, msgconv,msgbroker,sink,tee,NULL);
// Link elements
if (!gst_element_link_many(streammux,
nvdslogger, nvvideoconvert_reduce, capsFilter_reduce, nvtile, nvvidconv, nvosd, tee, NULL)) {
g_printerr (“Elements could not be linked. Exiting.\n”);
return -1;
if (!gst_element_link_many (queue1,msgconv,msgbroker, NULL)) {
g_printerr (“Elements could not be linked 3. Exiting.\n”);
return -1;
if (!gst_element_link (queue2, sink)) {
return -1;
gst_object_unref (osd_sink_pad);
sink_pad = gst_element_get_static_pad (queue1, “sink”);
tee_msg_pad = gst_element_request_pad_simple (tee, “src_%u”);
tee_render_pad = gst_element_request_pad_simple (tee, “src_%u”);
if (!tee_msg_pad || !tee_render_pad) {
g_printerr (“Unable to get request pads\n”);
return -1;
if (gst_pad_link (tee_msg_pad, sink_pad) != GST_PAD_LINK_OK) {
g_printerr (“Unable to link tee and message converter\n”);
gst_object_unref (sink_pad);
return -1;
sink_pad = gst_element_get_static_pad (queue2, “sink”);
if (gst_pad_link (tee_render_pad, sink_pad) != GST_PAD_LINK_OK) {
g_printerr (“Unable to link tee and render\n”);
return -1;
gst_element_release_request_pad (tee, tee_msg_pad);
gst_element_release_request_pad (tee, tee_render_pad);
gst_object_unref (tee_msg_pad);
gst_object_unref (tee_render_pad);
Rest of the code is same as original app
• DeepStream Version
• TensorRT Version
• Hardware Platform (Jetson / GPU) -GPU
• DeepStream Version -7.0
• NVIDIA GPU Driver Version (valid for GPU only)-555
• Issue Type( questions, new requirements, bugs)-new requirement
• How to reproduce the issue ? -modify the original app to add tee with msgbroker and msgconv
  1. could you share the whole log? if not add the new modifications, can the app run well?
  2. if add msgconv+fakesink instead of msgconv+msgbroker, can the app run well?
