After I convert the TRT model into an onnx file and put it in the place shown in the figure below, there are several other possible places, because I’m not sure where to put it. Finally, report this error. What happened?
- please keep in mind you need to share your setup with us when you create a topic in DS forum
- For your question, please make sure your model can run well with TensorRT before you deploy it on DS
OK,thanks.I will try
