Hi there,
while testing the new Isaac Sim release, I noticed that the Pose Estimation Synthetic Data Generation Example now produces an error (see below)
I’m using Isaac Sim 2022.2.0 on Windows 10. Can anyone help with a fix?
Hi there,
Hi there,
this issue seems to appear under windows. A quick workaround would be to remove the following two lines from site/sitecustomize.py
if os.path.exists(f"{p}/kit/extscore/omni.kit.window.viewport"):
sys.path.append(f"{p}/kit/extscore/omni.kit.window.viewport")
or, in the python script after SimulationApp starts add:
from omni.isaac.core.utils.extensions import enable_extension
enable_extension("omni.kit.window.viewport")
The fix will be included in version 2022.2.1
Best,
Andrei
