Pose Tracker in Composer - possible?
Currently, we can only use the Pose Tracker extension in the old Machinima.
I wonder if there is any way to enable this extension in Composer.
I tried adding the extscache from Machinima (c:/ov/pkg/machinima-2022.3.0/extscache) to Composer’s extension path, but only a few new extensions appeared in the list - without “omni.maxine.pose_estimation”.
I guess there are problems with the Kit version and so on, but maybe there is a way to do it?
We have aligned with MOVE.AI to support this same feature in USD Composer. Please switch to that workflow.
I am unable to find ‘Pose Tracker’ in Animation tool in Machinima application. Please help me solve the issue.
Machinima is a very very old product and should not be used. We do not support this in any way now.
Is it mandatory to import Move.Ai public asset library through extension, after launching ‘Create’ software? Because I am unable to find the Create App in the Exchange. And also I am unable to import the Move.AI asset library from the extension that is opened in Isaac Sim.
Please let me know alternate solutions to access Move.AI.
Also can you let me know alternate ways to get pose tracker, just want to explore it too. Do we need a licensed Version?
The Create App is the very old name for USD Composer. Don’t use Isaac Sim, use USD Composer. It is in there.
I am encountering a similar issue. Following the official documentation, I tried to locate the Pose Tracker plugin within Machinima but was unsuccessful. Pose Tracker — Omniverse Extensions latest documentation
Based on the discussion in this thread, I also attempted to find this plugin in USD Composer without any success. I tried to search for and install related plugins from the Extensions menu, but it seems that the extension named “omni.maxine.pose_estimation” could not be found.
Could you please advise if there is any additional extension package I need to install to enable this feature? Or are there any detailed steps that can guide me on how to correctly enable Pose Tracker in USD Composer? I am currently using USD Composer 2023.2.5 and Machinima-2022.3.0.
Thank you in advance for your assistance.
I have answered this post several times on this page.
DOWNLOAD HERE >> NVIDIA Omniverse extension | Move AI Help Center
Follow the instructions to install. Remember that where you see the word “Create” just replace with “Composer”
Thank you for this info. But the issue I am facing is, even after importing the Move.AI asset library file, I am unable to find The Move.AI extension.
Hence I had asked you previously that do we need a Licensed version for these features?
You may not have installed it correctly to the right folder. Make sure it is in this folder
“\Data\Kit\USD.Composer\2023.2\exts\3\moveai.assets.exts”
Thank you very much for the details. But still I cant find Move.AI extension. Please just let me know if I need Licensed version for this? As I have Omniverse SDK Installed.
No you do not need a license to install it and try it no.
Wait, Omniverse SDK ?? No you need USD COMPOSER 2023.2.5. The sdk is just for developing apps. Use Composer
