Possible Bug in NVIDIA Nsight Compute: FMUL2 FLOP Multiplier Missing in Nsight Compute Python Rule
While reviewing the NVIDIA Nsight Compute Python rules for roofline analysis, I noticed that the calculation for single-precision FLOP/s may be undercounting FMUL2 instructions. Specifically, in the Python file (e.g., SpeedOfLight_Roofline.py) generated by NVIDIA Nsight Compute, the line 155:
achieved_fp32 += fp32_add2_achieved *2 + fp32_mul2_achieved + 2 * fp32_fma2_achieved * 4
fp32_mul2_achieved is used directly, without multiplying by 2. However, according to the .section file (see SpeedOfLight_HierarchicalSingleRooflineChart.section), the correct FLOP count for FMUL2 should be:
smsp__sass_thread_inst_executed_op_fmul2_pred_on.sum.per_cycle_elapsed × 2
This is also reflected in the derived metric:
derived__smsp__sass_thread_inst_executed_op_fmul2_pred_on_x2: smsp__sass_thread_inst_executed_op_fmul2_pred_on.sum.per_cycle_elapsed * 2
Shouldn’t the Python rule multiply the FMUL2 metric by 2 to accurately reflect the number of FLOPs, since each FMUL2 instruction performs two operations? Is this omission a bug, or is there a reason for not applying the multiplier in the Python code?
Thanks for any clarification!
Nsight Compute version: 2025.4.0.0 (build 36690805) (public-release)
macOS version: 26.2 (25C56)
whole file:
# Copyright (c) 2025, NVIDIA CORPORATION. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
# are met:
#  * Redistributions of source code must retain the above copyright
#    notice, this list of conditions and the following disclaimer.
#  * Redistributions in binary form must reproduce the above copyright
#    notice, this list of conditions and the following disclaimer in the
#    documentation and/or other materials provided with the distribution.
#  * Neither the name of NVIDIA CORPORATION nor the names of its
#    contributors may be used to endorse or promote products derived
#    from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
# PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT OWNER OR
# CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
# PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
# OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
import NvRules
from RequestedMetrics import Importance, MetricRequest, RequestedMetricsParser
from TableBuilder import OpcodeTableBuilder
requested_metrics = [
    MetricRequest("device__attribute_compute_capability_major", "cc_major"),
    MetricRequest("device__attribute_compute_capability_minor", "cc_minor"),
    # This is currently collected in "SourceCounters" and "InstructionStatistics"
    # sections, do not warn if it is not available (as with the basic set).
    MetricRequest("inst_executed", None, Importance.OPTIONAL, None, False),
    MetricRequest("sm__sass_thread_inst_executed_op_ffma_pred_on.sum.peak_sustained", "inst_executed_ffma_peak"),
    MetricRequest("sm__sass_thread_inst_executed_op_dfma_pred_on.sum.peak_sustained", "inst_executed_dfma_peak"),
    MetricRequest("smsp__sass_thread_inst_executed_op_fadd_pred_on.sum.per_cycle_elapsed", "inst_executed_fadd"),
    MetricRequest("smsp__sass_thread_inst_executed_op_fmul_pred_on.sum.per_cycle_elapsed", "inst_executed_fmul"),
    MetricRequest("smsp__sass_thread_inst_executed_op_ffma_pred_on.sum.per_cycle_elapsed", "inst_executed_ffma"),
    MetricRequest("smsp__sass_thread_inst_executed_op_dadd_pred_on.sum.per_cycle_elapsed", "inst_executed_dadd"),
    MetricRequest("smsp__sass_thread_inst_executed_op_dmul_pred_on.sum.per_cycle_elapsed", "inst_executed_dmul"),
    MetricRequest("smsp__sass_thread_inst_executed_op_dfma_pred_on.sum.per_cycle_elapsed", "inst_executed_dfma"),
    MetricRequest("launch__uses_green_context", "is_green_context", Importance.OPTIONAL, False, False),
requested_metrics_gb10x = [
    MetricRequest("smsp__sass_thread_inst_executed_op_fadd2_pred_on.sum.per_cycle_elapsed", "inst_executed_fadd2"),
    MetricRequest("smsp__sass_thread_inst_executed_op_fmul2_pred_on.sum.per_cycle_elapsed", "inst_executed_fmul2"),
    MetricRequest("smsp__sass_thread_inst_executed_op_ffma2_pred_on.sum.per_cycle_elapsed", "inst_executed_ffma2"),
def get_identifier():
    return "SOLFPRoofline"
def get_name():
    return "Roofline Analysis"
def get_description():
    return "Floating Point Roofline Analysis"
def get_section_identifier():
    return "SpeedOfLight_RooflineChart"
def get_parent_rules_identifiers():
    return ["HighPipeUtilization"]
def get_estimated_speedup(parent_weights, achieved_fp32, achieved_fp64, peak_fp32, peak_fp64):
    # Estimate the speedup as the 64-bit portion of the compute workload, assuming
    # 32-bit FP pipeline has a higher throughput as 64-bit FP pipeline.
    # To get a global estimate weigh this with the 64-bit FP pipeline utilization
    # (in terms of active cycles).
    if peak_fp64 / peak_fp32 > 1:
        return NvRules.IFrontend.SpeedupType_LOCAL, 0
    improvement_local = (achieved_fp64 / (achieved_fp32 + achieved_fp64)) * (
        1 - peak_fp64 / peak_fp32
    if "fp64_pipeline_utilization_pct" in parent_weights:
        speedup_type = NvRules.IFrontend.SpeedupType_GLOBAL
        improvement_percent = improvement_local * parent_weights["fp64_pipeline_utilization_pct"]
    else:
        speedup_type = NvRules.IFrontend.SpeedupType_LOCAL
        improvement_percent = improvement_local * 100
    return speedup_type, improvement_percent
def add_fp64_instructions_table_and_source_markers(
    message_id,
    frontend,
    action,
    metrics,
    if metrics["inst_executed"] is None:
        return
    table_builder = OpcodeTableBuilder(
        workload=action,
        instruction_metric=metrics["inst_executed"],
        opcodes=["DADD", "DMUL", "DFMA"],
    header, data, config = table_builder.build(
        title="Most frequently executed FP64 instructions",
        description=(
            "Source lines with the highest number of executed"
            " 64-bit floating point instructions."
    if len(data) == 0:
        return
    frontend.generate_table(message_id, header, data, config)
    source_marker_advice = (
        "This line executes many 64-bit floating-point instructions."
        " Consider converting them to their 32-bit equivalents"
        " to improve performance."
    for aggregate in table_builder.get_aggregates():
        frontend.source_marker(
            source_marker_advice,
            aggregate.source_location.line,
            NvRules.MarkerKind.SOURCE,
            aggregate.source_location.path,
            NvRules.MsgType.OPTIMIZATION,
def apply(handle):
    ctx = NvRules.get_context(handle)
    action = ctx.range_by_idx(0).action_by_idx(0)
    fe = ctx.frontend()
    metrics = RequestedMetricsParser(handle, action).parse(requested_metrics)
    parent_weights = fe.receive_dict_from_parent("HighPipeUtilization")
    peak_fp32 = 2 * metrics["inst_executed_ffma_peak"].value()
    peak_fp64 = 2 * metrics["inst_executed_dfma_peak"].value()
    fp32_add_achieved = metrics["inst_executed_fadd"].value()
    fp32_mul_achieved = metrics["inst_executed_fmul"].value()
    fp32_fma_achieved = metrics["inst_executed_ffma"].value()
    achieved_fp32 = fp32_add_achieved + fp32_mul_achieved + 2 * fp32_fma_achieved
    cc_major = metrics["cc_major"].value()
    cc_minor = metrics["cc_minor"].value()
    if cc_major == 10 and (cc_minor == 0 or cc_minor == 3):
        metrics_gb10x = RequestedMetricsParser(handle, action).parse(requested_metrics_gb10x)
        fp32_add2_achieved = metrics_gb10x["inst_executed_fadd2"].value()
        fp32_mul2_achieved = metrics_gb10x["inst_executed_fmul2"].value()
        fp32_fma2_achieved = metrics_gb10x["inst_executed_ffma2"].value()
    fp64_add_achieved = metrics["inst_executed_dadd"].value()
    fp64_mul_achieved = metrics["inst_executed_dmul"].value()
    fp64_fma_achieved = metrics["inst_executed_dfma"].value()
    achieved_fp64 = fp64_add_achieved + fp64_mul_achieved + 2 * fp64_fma_achieved
    high_utilization_threshold = 0.60
    low_utilization_threshold = 0.15
    resource_partition = "device"
    if metrics["is_green_context"].value():
        resource_partition = "green context"
    achieved_fp64_pct = achieved_fp64 / peak_fp64
    fp64_prefix = "" if achieved_fp64_pct >= 0.01 or achieved_fp64_pct == 0.0 else " close to "
    achieved_fp32_pct = achieved_fp32 / peak_fp32
    fp32_prefix = "" if achieved_fp32_pct >= 0.01 or achieved_fp32_pct == 0.0 else " close to "
    message = "The ratio of peak float (FP32) to double (FP64) performance on this device is {:.0f}:1.".format(peak_fp32 / peak_fp64)
    message += " The workload achieved {}{:.0f}% of this {}'s FP32 peak performance and {}{:.0f}% of its FP64 peak performance.".format(fp32_prefix, 100.0 * achieved_fp32_pct, resource_partition, fp64_prefix, 100.0 * achieved_fp64_pct)
    message_profiling_guide = " See the @url:Profiling Guide:https://docs.nvidia.com/nsight-compute/ProfilingGuide/index.html#roofline@ for more details on roofline analysis."
    if achieved_fp32_pct < high_utilization_threshold and achieved_fp64_pct > low_utilization_threshold:
        message += " If @section:ComputeWorkloadAnalysis:Compute Workload Analysis@ determines that this workload is FP64 bound, consider using 32-bit precision floating point operations to improve its performance."
        message += message_profiling_guide
        msg_id = fe.message(NvRules.MsgType.OPTIMIZATION, message, "FP64/32 Utilization")
        speedup_type, speedup_value = get_estimated_speedup(parent_weights, achieved_fp32, achieved_fp64, peak_fp32, peak_fp64)
        fe.speedup(msg_id, speedup_type, speedup_value)
        if speedup_value > 0:
            fe.focus_metric(msg_id, metrics["inst_executed_dadd"].name(), fp64_add_achieved, NvRules.IFrontend.Severity_SEVERITY_HIGH, "Decrease FP64 ADD instructions")
            fe.focus_metric(msg_id, metrics["inst_executed_dmul"].name(), fp64_mul_achieved, NvRules.IFrontend.Severity_SEVERITY_HIGH, "Decrease FP64 MUL instructions")
            fe.focus_metric(msg_id, metrics["inst_executed_dfma"].name(), fp64_fma_achieved, NvRules.IFrontend.Severity_SEVERITY_HIGH, "Decrease FP64 FMA instructions")
        add_fp64_instructions_table_and_source_markers(msg_id, fe, action, metrics)
    elif achieved_fp64_pct > high_utilization_threshold and achieved_fp32_pct > high_utilization_threshold:
        message += " If @section:SpeedOfLight:Speed Of Light@ analysis determines that this workload is compute bound, consider using integer arithmetic instead where applicable."
        msg_id = fe.message(NvRules.MsgType.OPTIMIZATION, message, "High FP Utilization")
    else:
        msg_id = fe.message(NvRules.MsgType.OK, message, "Roofline Analysis")
Thanks for pointing out this formula issue !
Our dev has corrected this and it will update in future release. I will let you know when the release is published.
Thank you!
