This code produces an error with (pgf90 12.1-0 64-bit target on x86-64 Linux -tp istanbul)
I suspect there’s some confusion over the shm identifier but I am not sure.
The nagfor compiler (NAG Fortran Compiler Release 5.3 859)
rejects the code as non-valid f90 or f95 but accepts it as valid f2003 or f2008.
PGF90-S-0155-Derived type has not been declared - shm (shm_bug.f90: 17)
0 inform, 0 warnings, 1 severes, 0 fatal for constructor
PGF90-S-0155-Derived type has not been declared - shm (shm_bug.f90: 24)
0 inform, 0 warnings, 1 severes, 0 fatal for getshmid
module shm_mod
implicit none
private
public :: shm
type shm
integer :: shm_id = -999
contains
procedure :: shm => getShmid
!! above fails but with next line instead compiles ok
!! procedure :: shmoo => getShmid
end type shm
interface shm
procedure constructor
end interface
contains
function constructor (error)
class(shm), pointer :: constructor
integer :: error
! code missing
allocate(constructor)
error = 0
end function constructor
function getShmid (this)
class(shm) :: this
integer :: getShmid
getShmid = this%shm_id
end function getShmid
end module shm_mod
