I am trying to define a pointer procedure with optional arguments inside a derived datatype, using an abstract interface. The desired behavior is to use the procedure pointer to switch routines on the fly, if necessary.
Unfortunately, it seems that it is not possible to use optional arguments in Fortran abstract interfaces. The following code fails to compile using either pgfortran 18.10 or 19.10, but compiles with gfortran or ifort.
Compilation error is as follows:
$ pgfortran -c option.f90
PGF90-S-0188-Argument number 2 to proc_opts: type mismatch (option.f90: 40)
0 inform, 0 warnings, 1 severes, 0 fatal for use_opts
Source is shown below…
module optional_mod
type foo
real :: bar
procedure(sopt), pointer, pass(this) :: proc_opts
contains
procedure , pass(this) :: use_opts
procedure , pass(this) :: dummy_routine
end type foo
abstract interface
subroutine sopt(this,lopt)
import foo
implicit none
class(foo) :: this
logical, optional, intent(in) :: lopt
end subroutine sopt
end interface
contains
! Constructor
subroutine init(this)
implicit none
class(foo) :: this
!Initialize the procedure pointer
this%proc_opts => dummy_routine
end subroutine init
! Call procedure pointer without optional argument
subroutine use_opts(this)
implicit none
class(foo) :: this
call this%proc_opts()
end subroutine use_opts
! Dummy routine
subroutine dummy_routine(this,lopt)
implicit none
class(foo) :: this
if (present(lopt)) then
write (*,*) "Optional parameter present"
else
write (*,*) "Optional parameter not present"
end if
end subroutine dummy_routine
end module optional_mod
It is quite possible that this problem can be circumvented by duplicating the routines and using an interface to differentiate between them, but I haven’t tried that yet.
Thank you for your help!
