Possible issues with cudaMallocManaged() when used wtih a vGPU?
we have code written for usage on a system supporting unified memory functionality (e.g. jetson agx). The used cudaMallocManaged() method ensures that the code will run on a system without unified memory, too. But what about cudaMallocManaged() when using vGPU (e.g. 2Q on RTX 6000)? Are there any issue that might occur on a virtualized GPU?
Many thanks in advance!
https://docs.nvidia.com/cuda/vGPU/index.html
Currently, that page says:
The following CUDA features are not supported on vGPU:
Unified Memory
(This could change in the future)
So using cudaMallocManaged() with vGPU will throw an cudaErrorNotSupported, right?
Thank you for your fast reply!
