I have the following simple GLSL fragment shader:
#version 460
#extension GL_EXT_shader_explicit_arithmetic_types_int64 : enable
layout(location = 0) out vec4 out_color;
layout(location = 0) flat in uint64_t in_a;
void main() {
if(findLSB(in_a) == 0u)
out_color = vec4(0.5);
else
out_color = vec4(1);
The value of in_a is set to 1 in the vertex shader. The expectation is that the out_color should be grey but it’s white instead.
I’ve replaced the if() with if(in_a == 1u) and in_a appears to be 1 as expected.
I’ve also replaced the if() with if(findLSB(uint(in_a)) == 0u) and that returns grey which is also expected.
So there must be something wrong with findLSB and 64bit integers.
This is the relevant parts of the generated SPIR-V:
%1 = OpExtInstImport "GLSL.std.450"
%ulong = OpTypeInt 64 0
%long = OpTypeInt 64 1
%9 = OpLoad %ulong %in_a
%11 = OpExtInst %long %1 FindILsb %9
I’m not a SPIR-V expert but the generated code appears to be correct.
