I would like to know if there is any way to specify in a !cuf kernel directive that it must run the loop on a particular stream, because pgfortran refuses to compile the program below and reports a syntax error.
program mysum
use cudafor
IMPLICIT NONE
integer,parameter::n=13,nStreams=4
integer :: stream(nStreams)
real:: xx(n)
real, device:: xx_dev(n)
real val
integer i,istat
do i = 1, nStreams
istat = cudaStreamCreate(stream(i))
enddo
write(*,*) stream
do i=1,n
xx(i)=real(i)
enddo
write(*,*) xx
xx_dev=xx
val = 0.0
!$cuf kernel do {{{ *, *, 0, stream(1) }}}
do i=1,n
val = val+xx_dev(i)
enddo
write(*,*) sum(xx),val
end program mysum
thanks.
(Note: in the chevron syntax, please replace the curly braces with angle brackets because the angle brackets did not display the contents inside it correctly, which is probably some HTML issue)
