I’m building two systems and have B04 and C02 dev boards. It’s clear I can wire an external LED to show the power status of the board on the B04, but I can’t see any documentation if this is available on the J20 header on the C02.
The issue is that while the B04 switches on with a quick (power) button press, the C02 seems to require pressing and holding the power button for about a second for it to boot. Holding the power button for less time causes momentary lighting of onboard LEDs, but on release they fade back to black and the board does not boot. The idea is the external LED will indicate whether the power button has been held for a sufficient time to boot board.
