I’ve gone through most all steps I can think of, but the result is the same: I cannot configure the jetson.
My setup is as in the headless setup guide:
. linux pc
. usb micro cable
. sudo tio /dev/ttyACM0
What happens:
Absolutely nothing.
It just hangs.
So, I tried everything: monitor/keyboard, no dice.
When I put it into force recovery mode, with the serial terminal to ttyACM0 (and the rest; same result), it gives me the boot log… but I don’t see anything wrong with it; it looks like the boot log of my working jetson. At the end, it says “jetson still needs to be configured”, so I exit / re-connect, and once more, it hangs.
I’ve tried to re-flash / image it with the sdkmanager, but it won’t detect it.
Since the normal ways, the force recovery way, and the sdkmanager all couldn’t seem to connect or interface with the jetson… I feel like its defective?
Support said I had to confirm with the forum, to make sure.
