Post-installation Script Shows File Access Error and RPC Connection Reset on Windows 11
Isaac Sim Version
[v] 4.2.0
Operating System
[v] Windows 11
GPU Information
  • Model: geforce 3060
  • Driver Version: 560
Topic Description
Detailed Description
I’m encountering two issues while running the post-installation scripts of Isaac Sim 4.2.0 on Windows 11.
  • When executing omni.isaac.sim.post.install.bat, the script finishes with a message saying “Isaac Sim Post-Installation Script completed!”, but also shows an error:
    “다른 프로세스가 파일을 사용 중이기 때문에 프로세스가 액세스 할 수 없습니다.”
    (Translation: “The process cannot access the file because it is being used by another process.”)
  • When executing omni.isaac.sim.warmup.bat, I receive the following error in the console related to RPC:
    ConnectionReset from 127.0.0.1
    This seems to happen while warming up the shader cache or establishing RPC communication.
I expected the scripts to run without any file access or communication errors.
Steps to Reproduce
  1. Download and install Isaac Sim 4.2.0 via Omniverse Launcher on Windows 11
  2. Navigate to C:\Users\KIRO\AppData\Local\ov\pkg\isaac-sim-420\
  3. Run omni.isaac.sim.post.install.bat
  4. Observe the message and file access error
  5. Run omni.isaac.sim.warmup.bat
  6. Observe the RPC connection reset error in the terminal
Error Messages
Post-installation script output:
Warming up shader cache... Please wait...
Close this window to skip.
Warm-up script output:
2025-04-09T07:43:48.430524Z ERROR hub-001 ThreadId(12) hub::rpc::server_msgpack: hub\src\rpc\server_msgpack.rs:169: Error reading message from client 127.0.0.1:2799: Os { code: 10054, kind: ConnectionReset, message: "현재 연결은 원격 호스트에 의해 강제로 끊겼습니다." } (Translation: "The connection was forcibly closed by the remote host.")
2025-04-09T07:43:48.430931Z INFO hub-001 ThreadId(12) hub::rpc::server_msgpack: hub\src\rpc\server_msgpack.rs:172: Connection from 127.0.0.1:2799 closed
Additional Information
What I’ve Tried
  • Restarted the PC and ran the scripts again
  • Checked Task Manager for other processes possibly using files in the Isaac Sim directory
Additional Context
  • Running on Windows 11
  • Using Isaac Sim 4.2.0
  • This is part of initial post-installation setup
  • No GPU driver or hardware errors noted so far
Please check if Isaac Sim Python App Not Caching Shaders, Waiting for compilation of ray tracing shaders for RTX renderer is helpful.
