• Hardware Platform (Jetson / GPU) GTX 1650 • DeepStream Version 5 • TensorRT Version 7.0.0.11 • NVIDIA GPU Driver Version (valid for GPU only) 450.51 • Issue Type( questions, new requirements, bugs) question
I am using Python API, deepstream-test2. I want to do post-processing on the output detection boxes (draw only boxes that lies inside a given ROI, and draw certain classes). How can I do that? and can I call some function that uses opencv in there?
I have a post-processing function that say calculates the area of the detection boxes. Where can I add it?. I called it from inside deepstream_test_2.py and passed the frame_meta.obj_meta_list to it. It is working, but is that the right approach?.
For the certain classes issue, I updated the parsing function, built it, and used it in the configuration file like that
If you are using c/c++, so you can refer nvdsinfer_custombboxparser.cpp for how to write the customized post process parser and then in your nvinfer config file set following item:
