hello ticotimo,
Q1>
ya, that should be using pyhton3, it should be comment messages did not up to date.
Q2>
- command-line with
--noburn.sudo FAB=400 BOARDID=2888 BOARDSKU=0001 BOARDREV=L.0 ./odmfuse.sh -i 0x19 -p --noburn --auth SBKPKC -k ../rsa_priv.pem --KEK2 ../kek2_hex_file --KEK256 ../kek256_hex_file -S ../sbk_hex_file jetson-agx-xavier-devkit- this command-line is running at offline mode, in the offline mode, the
--authoptions is used to indicate the board fuse status, because there is no boards connected, soodmfuse.shdoesn’t have a chance to know the board’s fuse status. - in this scenario… since the target has burned with PKC+SBK,
-kis used to sign the encrypted images;-Sis the command to encrypt the images. in the end, there only--KEK2andKEK256will be burned to the board, then it appears in theodmfuse_pkc.xml.
- command-line with
--test.sudo ./odmfuse.sh --test -i 0x19 -c SBKPKC -p -k ../rsa_priv.pem -S ../sbk_hex_file --KEK2 ../kek2_hex_file --KEK256 ../kek256_hex_file jetson-agx-xavier-devkit- since there is neither board info nor
--noburnin the command,odmfuse.shwill run in the online mode, which means a board must be connected;-coptions is no needed in the online mode sinceodmfuse.shis now able to get the board’s fuse status from the target. besides, the option-cis obsolete now. it’s replace by--authoptions. - I assume you’re test this pipeline with unfused target, right? you should assign
--auth NSoptions to the command-line due to neither PKC nor SBK is burned. - following above, for these options in the command-line, all fuse info will be burn to the target, such as…
-p,-k,-S,-KEK2,-KEK256. so, that’s whyodmfuse_pkc.xmlinclude all those fuse information.
Q3>
the 3072-bit RSA key option is supported only on Jetson Xavier series.
Q4>
please use the multi-steps approaches to burn the fuse and flash the target.
for example, (1) using odmfuse.sh to create the fuse blob, (2) review all the fuse info and messages, running fusecmd.sh to burn the fuse to the device actually, (3) it’s flash.sh script to create the image blob, and (4) run flashcmd.txt to flash the target. please see-also this thread for reference, Jetson Xavier NX DEVKIT secureboot enabled - #7 by JerryChang
