Could you guide how to get to the docker in order to enter the realsense-viewer
command?
2025-02-05 13:29:55 [mona@DOS isaac_ros_common]$ ./scripts/run_dev.sh -d ${ISAAC_ROS_WS}
Launching Isaac ROS Dev container with image key x86_64.ros2_humble.realsense: /home/mona/workspaces/isaac_ros-dev/
Building x86_64.ros2_humble.realsense base as image: isaac_ros_dev-x86_64
Building layered image for key x86_64.ros2_humble.realsense as isaac_ros_dev-x86_64
Using configured docker search paths: /home/mona/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker
Checking if base image nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble-realsense_abaf95dbad7ec06f92397c4406c5ffea exists on remote registry
Checking if base image nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble_e46da4110307fe0d4de2a3060b8e9ba8 exists on remote registry
Found pre-built base image: nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble_e46da4110307fe0d4de2a3060b8e9ba8
x86_64-ros2_humble_e46da4110307fe0d4de2a3060b8e9ba8: Pulling from nvidia/isaac/ros
762bedf4b1b7: Pulling fs layer
0b41952b72ac: Pulling fs layer
4f4fb700ef54: Pulling fs layer
07ba40811e97: Waiting
5225d47729a1: Waiting
a6736266741e: Waiting
1d4f5bd6b322: Waiting
31b0ebce44a6: Waiting
80331719ab01: Waiting
89611129266d: Waiting
a6fb8d7f959b: Waiting
92d994dcc9cf: Waiting
5bb995e55ec8: Waiting
9a2596b7b726: Waiting
38b603e618b6: Waiting
afc54cea18f1: Waiting
62f4d4da0738: Waiting
d94d36e98e89: Waiting
60cfd9f68907: Waiting
2bb596bab1e2: Waiting
c615c8bc82c0: Waiting
0a747185c88f: Waiting
48c7083f891b: Waiting
eaf9e58efb13: Waiting
b7e9c73673f3: Waiting
4f56b37681fc: Waiting
29d24ca43a63: Waiting
e27256ab9df6: Waiting
ac90b17120dc: Waiting
c2072f422b96: Waiting
22159efba9bc: Waiting
ef695987e0bc: Waiting
34313d4c6f10: Waiting
dff5597c50e2: Waiting
08b712bb78e2: Waiting
8352d0ac536f: Waiting
91bfddee3525: Waiting
3ede5376a9c9: Waiting
efc28114f793: Waiting
36ef679bb658: Waiting
08af7cdb3912: Waiting
5822c07125e4: Waiting
31c6d758f99b: Waiting
6b8754d7ce3a: Waiting
4ee0f5c16db4: Waiting
307e6eeb0300: Pull complete
8ad490131253: Pull complete
a1a851be9b63: Pull complete
318ed65bac87: Pull complete
35cf531fd48c: Pull complete
702811291b5c: Pull complete
b101bbafea9f: Pull complete
1967cb11ec29: Pull complete
0d88d95c78dd: Pull complete
561c34e85e42: Pull complete
5b6fac9f2a45: Pull complete
feb82ff1d636: Pull complete
30cd2439103a: Pull complete
9083985ceb3a: Pull complete
5c6009973d20: Pull complete
ef5b1520155c: Pull complete
61963dc5da35: Pull complete
757831ca3a97: Pull complete
2847bf45b162: Pull complete
698a692cc0d6: Pull complete
4277eabf57d9: Pull complete
7428777c8522: Pull complete
87a496d84115: Pull complete
da06f42e1c6d: Pull complete
0889ce1dd927: Pull complete
229e6cd115a6: Pull complete
e450bbeadbc7: Pull complete
60d0c2bdb6c1: Pull complete
1386a6a8500e: Pull complete
fcd4579359f7: Pull complete
6b6359f3a967: Pull complete
2aed228084f1: Pull complete
1651ffc0a6ef: Pull complete
0d21606f264c: Pull complete
8e589a966100: Pull complete
f4ab687b836e: Pull complete
8bc6e5f7844b: Pull complete
Digest: sha256:55f37ea84f849522d43b7b364429be4fc0ea5862d728186fcf84814f34d338f5
Status: Downloaded newer image for nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble_e46da4110307fe0d4de2a3060b8e9ba8
Finished pulling pre-built base image: nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble_e46da4110307fe0d4de2a3060b8e9ba8
Resolved the following 1 Dockerfiles for target image: x86_64.ros2_humble.realsense
/home/mona/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.realsense
Building /home/mona/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.realsense as image: isaac_ros_dev-x86_64 with base: nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble_e46da4110307fe0d4de2a3060b8e9ba8
[+] Building 1281.2s (13/13) FINISHED docker:default
=> [internal] load build definition from Dockerfile.realsense 0.0s
=> => transferring dockerfile: 2.42kB 0.0s
=> [internal] load metadata for nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble_e46da4110307fe0d4de2a3060b8e9ba8 0.0s
=> [internal] load .dockerignore 0.0s
=> => transferring context: 2B 0.0s
=> [stage-0 1/8] FROM nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble_e46da4110307fe0d4de2a3060b8e9ba8 5.3s
=> [internal] load build context 0.2s
=> => transferring context: 11.54kB 0.0s
=> [stage-0 2/8] COPY scripts/build-librealsense.sh /opt/realsense/build-librealsense.sh 3.2s
=> [stage-0 3/8] COPY scripts/install-realsense-dependencies.sh /opt/realsense/install-realsense-dependencies.sh 0.1s
=> [stage-0 4/8] RUN chmod +x /opt/realsense/install-realsense-dependencies.sh && /opt/realsense/install-realsense-dependencie 1098.9s
=> [stage-0 5/8] RUN mkdir -p /opt/realsense/ 0.1s
=> [stage-0 6/8] COPY scripts/hotplug-realsense.sh /opt/realsense/hotplug-realsense.sh 0.1s
=> [stage-0 7/8] COPY udev_rules/99-realsense-libusb-custom.rules /etc/udev/rules.d/99-realsense-libusb-custom.rules 0.1s
=> [stage-0 8/8] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src && git 170.8s
=> exporting to image 2.2s
=> => exporting layers 2.1s
=> => writing image sha256:62d10d129dbb3a3a7f4ecf73dd9d90c986de122e9bcf0850d46916a045d3ef92 0.0s
=> => naming to docker.io/library/isaac_ros_dev-x86_64 0.0s
Running isaac_ros_dev-x86_64-container
Creating non-root container 'admin' for host user uid=1002:gid=1002
* Stopping hotplug events dispatcher systemd-udevd [ OK ]
* Starting hotplug events dispatcher systemd-udevd [ OK ]
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
admin@DOS:/workspaces/isaac_ros-dev$
https://nvidia-isaac-ros.github.io/getting_started/hardware_setup/sensors/realsense_setup.html
