I want to control my jetson nano with buttons like open-close, suspend-wake up and restart buttons for an application. Can you help me for this issue.
Thank you
Thank you
Hi ismailyesilyurt.80, you can connect momentary push-buttons for Power-On, Reset, and Force Recovery to the pins on the J40 button header, please refer to pages 6 & 7 of the Jetson Nano Developer Kit User Guide: https://developer.nvidia.com/embedded/dlc/jetson-nano-dev-kit-user-guide
J40 Button Header
You can also simply short these pins with a standard 2.54mm shunt jumper if that’s easier.
Thank you for your reply. That is very helpful for me but I can not fix suspend for the reduce power consumption.
can you explain for me that why we use force recovery mode?
Thank you.
Dear all,
With USB Port at bottom position, J40 is at top left corner.
External Media
I put a jumper at second row from the bottom (pin 3-4). Power Nano on, I remove the jumper.
Then I issue command $ sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
But failed with
Error: Return value 1
Command tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
Failed flashing t210ref.
Is the cause came from sdcard writing speed? I am using a 32 GB Sandisk Ultra.
suryadi@xtal:~/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra$ sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
[sudo] password for suryadi:
# L4T BSP Information:
# R32 , REVISION: 2.0
# Target Board Information:
# Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x21 --applet "/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0011 ] Generating RCM messages
[ 0.0018 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0025 ] RCM 0 is saved as rcm_0.rcm
[ 0.0029 ] RCM 1 is saved as rcm_1.rcm
[ 0.0029 ] List of rcm files are saved in rcm_list.xml
[ 0.0029 ]
[ 0.0029 ] Signing RCM messages
[ 0.0035 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0041 ] Assuming zero filled SBK key
[ 0.0080 ]
[ 0.0080 ] Copying signature to RCM mesages
[ 0.0087 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0096 ]
[ 0.0097 ] Boot Rom communication
[ 0.0103 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0109 ] RCM version 0X210001
[ 0.0549 ] Boot Rom communication completed
[ 1.0633 ]
[ 1.0636 ] dump EEPROM info
[ 1.0666 ] tegrarcm --oem platformdetails eeprom /home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0698 ] Applet version 00.01.0000
[ 1.0880 ] Saved platform info in /home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1649 ]
Board ID(3448) version(200)
creating dummy /home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/badpage.bin
1+0 records in
1+0 records out
4096 bytes (4,1 kB, 4,0 KiB) copied, 0,000111073 s, 36,9 MB/s
copying bctfile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating /home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
Copying nv_boot_control.conf to rootfs
Making system.img...
populating rootfs from /home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 9437184( 9 blks) ==> 28:9437196
1: SKP: 28311552( 27 blks) ==> 9437224:12
2: RAW: 13631488( 13 blks) ==> 9437236:13631500
3: SKP: 82837504( 79 blks) ==> 23068736:12
4: RAW: 1048576( 1 blks) ==> 23068748:1048588
5: SKP: 3145728( 3 blks) ==> 24117336:12
6: RAW: 27262976( 26 blks) ==> 24117348:27262988
7: SKP: 1048576( 1 blks) ==> 51380336:12
8: RAW: 44040192( 42 blks) ==> 51380348:44040204
9: SKP: 15728640( 15 blks) ==> 95420552:12
10: RAW: 177209344( 169 blks) ==> 95420564:177209356
11: SKP: 3145728( 3 blks) ==> 272629920:12
12: RAW: 217055232( 207 blks) ==> 272629932:217055244
13: SKP: 1048576( 1 blks) ==> 489685176:12
14: RAW: 47185920( 45 blks) ==> 489685188:47185932
15: SKP: 3145728( 3 blks) ==> 536871120:12
16: RAW: 46137344( 44 blks) ==> 536871132:46137356
17: SKP: 1048576( 1 blks) ==> 583008488:12
18: RAW: 218103808( 208 blks) ==> 583008500:218103820
19: SKP: 3145728( 3 blks) ==> 801112320:12
20: RAW: 265289728( 253 blks) ==> 801112332:265289740
21: SKP: 3145728( 3 blks) ==> 1066402072:12
22: RAW: 25165824( 24 blks) ==> 1066402084:25165836
23: SKP: 1048576( 1 blks) ==> 1091567920:12
24: RAW: 262144000( 250 blks) ==> 1091567932:262144012
25: SKP: 1048576( 1 blks) ==> 1353711944:12
26: RAW: 175112192( 167 blks) ==> 1353711956:175112204
27: SKP: 1048576( 1 blks) ==> 1528824160:12
28: RAW: 15728640( 15 blks) ==> 1528824172:15728652
29: SKP: 1048576( 1 blks) ==> 1544552824:12
30: RAW: 13631488( 13 blks) ==> 1544552836:13631500
31: SKP: 3145728( 3 blks) ==> 1558184336:12
32: RAW: 38797312( 37 blks) ==> 1558184348:38797324
33: SKP: 3145728( 3 blks) ==> 1596981672:12
34: RAW: 39845888( 38 blks) ==> 1596981684:39845900
35: SKP: 2097152( 2 blks) ==> 1636827584:12
36: RAW: 30408704( 29 blks) ==> 1636827596:30408716
37: SKP: 3145728( 3 blks) ==> 1667236312:12
38: RAW: 37748736( 36 blks) ==> 1667236324:37748748
39: SKP: 4194304( 4 blks) ==> 1704985072:12
40: RAW: 15728640( 15 blks) ==> 1704985084:15728652
41: SKP: 261095424( 249 blks) ==> 1720713736:12
42: RAW: 6291456( 6 blks) ==> 1720713748:6291468
43: SKP: 27262976( 26 blks) ==> 1727005216:12
44: RAW: 13631488( 13 blks) ==> 1727005228:13631500
45: SKP: 87031808( 83 blks) ==> 1740636728:12
46: RAW: 838860800( 800 blks) ==> 1740636740:838860812
47: SKP: 33554432( 32 blks) ==> 2579497552:12
48: RAW: 23068672( 22 blks) ==> 2579497564:23068684
49: SKP: 178257920( 170 blks) ==> 2602566248:12
50: RAW: 1048576( 1 blks) ==> 2602566260:1048588
51: SKP: 267386880( 255 blks) ==> 2603614848:12
52: RAW: 1048576( 1 blks) ==> 2603614860:1048588
53: SKP: 670040064( 639 blks) ==> 2604663448:12
54: RAW: 5242880( 5 blks) ==> 2604663460:5242892
55: SKP: 28311552( 27 blks) ==> 2609906352:12
56: RAW: 9437184( 9 blks) ==> 2609906364:9437196
57: SKP: 91226112( 87 blks) ==> 2619343560:12
58: RAW: 115343360( 110 blks) ==> 2619343572:115343372
59: SKP: 2097152( 2 blks) ==> 2734686944:12
60: RAW: 341835776( 326 blks) ==> 2734686956:341835788
61: SKP: 1553989632( 1482 blks) ==> 3076522744:12
62: RAW: 6291456( 6 blks) ==> 3076522756:6291468
63: SKP: 27262976( 26 blks) ==> 3082814224:12
64: RAW: 11534336( 11 blks) ==> 3082814236:11534348
65: SKP: 89128960( 85 blks) ==> 3094348584:12
66: RAW: 1048576( 1 blks) ==> 3094348596:1048588
67: SKP: 3145728( 3 blks) ==> 3095397184:12
68: RAW: 188743680( 180 blks) ==> 3095397196:188743692
69: SKP: 8388608( 8 blks) ==> 3284140888:12
70: RAW: 33554432( 32 blks) ==> 3284140900:33554444
71: SKP: 1778384896( 1696 blks) ==> 3317695344:12
72: RAW: 10485760( 10 blks) ==> 3317695356:10485772
73: SKP: 23068672( 22 blks) ==> 3328181128:12
74: RAW: 17825792( 17 blks) ==> 3328181140:17825804
75: SKP: 82837504( 79 blks) ==> 3346006944:12
76: RAW: 136314880( 130 blks) ==> 3346006956:136314892
77: SKP: 1876951040( 1790 blks) ==> 3482321848:12
78: RAW: 5242880( 5 blks) ==> 3482321860:5242892
79: SKP: 28311552( 27 blks) ==> 3487564752:12
80: RAW: 15728640( 15 blks) ==> 3487564764:15728652
81: SKP: 84934656( 81 blks) ==> 3503293416:12
82: RAW: 1048576( 1 blks) ==> 3503293428:1048588
83: SKP: 3145728( 3 blks) ==> 3504342016:12
84: RAW: 175112192( 167 blks) ==> 3504342028:175112204
85: SKP: 1833959424( 1749 blks) ==> 3679454232:12
86: RAW: 6291456( 6 blks) ==> 3679454244:6291468
87: SKP: 27262976( 26 blks) ==> 3685745712:12
88: RAW: 13631488( 13 blks) ==> 3685745724:13631500
89: SKP: 87031808( 83 blks) ==> 3699377224:12
90: RAW: 656408576( 626 blks) ==> 3699377236:656408588
91: SKP: 1356857344( 1294 blks) ==> 4355785824:12
-- Total: ---------------------------------------------------
92 CHUNK 15032385536( 14336 blks) ==> 4355785836(4154 blks)
done.
system.img built successfully.
Existing tbcfile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
copying cfgfile(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
copying flasher(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a02.dtb"
saving flash command in /home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0069 ] tegrasign --key None --getmode mode.txt
[ 0.0094 ] Assuming zero filled SBK key
[ 0.0098 ]
[ 0.0099 ] Generating RCM messages
[ 0.0189 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0213 ] RCM 0 is saved as rcm_0.rcm
[ 0.0225 ] RCM 1 is saved as rcm_1.rcm
[ 0.0225 ] List of rcm files are saved in rcm_list.xml
[ 0.0225 ]
[ 0.0226 ] Signing RCM messages
[ 0.0250 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0274 ] Assuming zero filled SBK key
[ 0.0340 ]
[ 0.0340 ] Copying signature to RCM mesages
[ 0.0347 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0489 ]
[ 0.0489 ] Parsing partition layout
[ 0.1206 ] tegraparser --pt flash.xml.tmp
[ 0.2130 ]
[ 0.2131 ] Creating list of images to be signed
[ 0.2628 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.4147 ]
[ 0.4148 ] Generating signatures
[ 0.4167 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.4183 ] Assuming zero filled SBK key
[ 0.6226 ]
[ 0.6226 ] Generating br-bct
[ 0.6627 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.6637 ] Copying Sdram info from 0 to 1 set
[ 0.7624 ] Copying Sdram info from 1 to 2 set
[ 0.7624 ] Copying Sdram info from 2 to 3 set
[ 0.7625 ]
[ 0.7625 ] Updating boot device parameters
[ 0.7654 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.7680 ] Warning: No sdram params
[ 0.7721 ]
[ 0.7722 ] Updating bl info
[ 0.7746 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.7936 ]
[ 0.7938 ] Updating secondary storage information into bct
[ 0.7964 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.8056 ]
[ 0.8057 ] Updating Odmdata
[ 0.8083 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 0.8107 ] Warning: No sdram params
[ 0.8156 ]
[ 0.8157 ] Get Signed section of bct
[ 0.8181 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.8210 ]
[ 0.8211 ] Signing BCT
[ 0.8261 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.8285 ] Assuming zero filled SBK key
[ 0.8298 ]
[ 0.8299 ] Updating BCT with signature
[ 0.8323 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.8404 ]
[ 0.8406 ] Copying signatures
[ 0.8433 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.8927 ]
[ 0.8929 ] Updating BFS information on BCT
[ 0.8954 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.9004 ]
[ 0.9006 ] Boot Rom communication
[ 0.9030 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.9055 ] BootRom is not running
[ 0.9481 ]
[ 0.9482 ] Sending BCTs
[ 0.9509 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.9534 ] Applet version 00.01.0000
[ 0.9703 ] Sending bct
[ 0.9707 ] [................................................] 100%
[ 1.1438 ]
[ 1.1469 ] tegrahost --chip 0x21 --align cboot.bin
[ 1.1502 ]
[ 1.1530 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 1.1593 ]
[ 1.1664 ] tegrasign --key None --list cboot.bin_list.xml
[ 1.1689 ] Assuming zero filled SBK key
[ 1.2048 ]
[ 1.2064 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 1.2083 ]
[ 1.2102 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
[ 1.2112 ]
[ 1.2121 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
[ 1.2137 ]
[ 1.2148 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
[ 1.2157 ] Assuming zero filled SBK key
[ 1.2225 ]
[ 1.2238 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
[ 1.2251 ]
[ 1.2255 ] Sending bootloader and pre-requisite binaries
[ 1.2264 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
[ 1.2273 ] Applet version 00.01.0000
[ 1.2462 ] Sending ebt
[ 1.2467 ] [................................................] 100%
[ 1.3590 ] Sending rp1
[ 1.3634 ] [................................................] 100%
[ 1.4142 ]
[ 1.4171 ] tegrarcm --boot recovery
[ 1.4200 ] Applet version 00.01.0000
[ 1.4388 ]
[ 1.4389 ] Retrieving storage infomation
[ 1.4416 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 1.4441 ] Applet is not running on device. Continue with Bootloader
[ 2.1867 ]
[ 2.1889 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 2.1899 ] Cboot version 00.01.0000
[ 2.1931 ] Saved platform info in storage_info.bin
[ 2.1943 ]
[ 2.1943 ] Flashing the device
[ 2.1953 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 2.1962 ] Cboot version 00.01.0000
[ 2.2138 ] Writing partition GPT with gpt.bin
[ 2.2146 ] [................................................] 100%
[ 2.2182 ] Writing partition NVC with nvtboot.bin.encrypt
[ 16.1398 ] [................................................] 100%
[ 16.1503 ] Writing partition PT with flash.xml.bin
[ 26.6478 ] [................................................] 100%
[ 26.6515 ] Writing partition NVC_R with nvtboot.bin.encrypt
[ 26.9026 ] [................................................] 100%
[ 26.9190 ] Writing partition VER with qspi_bootblob_ver.txt
[ 37.4295 ] [................................................] 100%
[b][ 37.4401 ] Writing partition APP with system.img
[ 85.5180 ] [..... ] 010%
Failed flashing t210ref.[/b]
Second attempt
[ 1.4064 ] Flashing the device
[ 1.4075 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 1.4086 ] Cboot version 00.01.0000
[ 1.4247 ] Writing partition GPT with gpt.bin
[ 1.4253 ] [................................................] 100%
[ 1.4300 ] Writing partition NVC with nvtboot.bin.encrypt
[ 15.2935 ] [................................................] 100%
[ 15.3037 ] Writing partition PT with flash.xml.bin
[ 25.8029 ] [................................................] 100%
[ 25.8074 ] Writing partition NVC_R with nvtboot.bin.encrypt
[ 26.0577 ] [................................................] 100%
[ 26.0745 ] Writing partition VER with qspi_bootblob_ver.txt
[ 36.5850 ] [................................................] 100%
[ 36.5976 ] Writing partition APP with system.img
[ 38.3853 ] [ ] 000%
Third attempt
[ 1.6129 ] Flashing the device
[ 1.6140 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 1.6150 ] Cboot version 00.01.0000
[ 1.6347 ] Writing partition GPT with gpt.bin
[ 1.6350 ] [................................................] 100%
[ 1.6389 ] Writing partition NVC with nvtboot.bin.encrypt
[ 15.3618 ] [................................................] 100%
[ 15.3726 ] Writing partition PT with flash.xml.bin
[ 25.8710 ] [................................................] 100%
[ 25.8744 ] Writing partition NVC_R with nvtboot.bin.encrypt
[ 26.1241 ] [................................................] 100%
[ 26.1401 ] Writing partition VER with qspi_bootblob_ver.txt
[ 36.6539 ] [................................................] 100%
[ 36.6670 ] Writing partition APP with system.img
[ 38.4449 ] [ ] 000%
Fourth Attempt using SDK Manager
2019-08-08 20:11:40.566 - info: [ 1.6150 ] Flashing the device
2019-08-08 20:11:40.566 - info: [ 1.6178 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
2019-08-08 20:11:40.566 - info: [ 1.6207 ] Cboot version 00.01.0000
2019-08-08 20:11:40.566 - info: [ 1.6369 ] Writing partition GPT with gpt.bin
2019-08-08 20:11:40.566 - info: [ 1.6375 ] [...] 100%
2019-08-08 20:11:54.253 - info: [ 1.6414 ] Writing partition NVC with nvtboot.bin.encrypt
2019-08-08 20:11:54.309 - info: [ 15.3951 ] [...] 100%
2019-08-08 20:12:04.759 - info: [ 15.4044 ] Writing partition PT with flash.xml.bin
2019-08-08 20:12:04.842 - info: [ 25.9039 ] [...] 100%
2019-08-08 20:12:05.012 - info: [ 25.9084 ] Writing partition NVC_R with nvtboot.bin.encrypt
2019-08-08 20:12:05.072 - info: [ 26.1576 ] [...] 100%
2019-08-08 20:12:15.539 - info: [ 26.1731 ] Writing partition VER with qspi_bootblob_ver.txt
2019-08-08 20:12:15.628 - info: [ 36.6844 ] [...] 100%
[b]2019-08-08 20:12:15.810 - info: [ 36.6943 ] Writing partition APP with system.img
2019-08-08 20:12:48.483 - info: [ 36.9550 ] [ ] 000%
[ 36.9550 ] [... ] 008%
[ 69.6216 ]
2019-08-08 20:12:48.484 - info: Error: Return value 1
2019-08-08 20:12:48.485 - info: Command tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
2019-08-08 20:12:48.568 - info: Failed flashing t210ref.
2019-08-08 20:12:48.568 - info: exit status 1[/b]
2019-08-08 20:12:48.568 - info: [ Component Install Finished with Error ]
2019-08-08 20:12:48.568 - error: NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
2019-08-08 20:12:48.568 - info: [ 7.13 MB used. Disk Avail: 112.47 GB ]
2019-08-08 20:12:48.568 - info: [ NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP Install took 1m47s ]
2019-08-08 20:12:48.568 - info: command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
2019-08-08 20:12:48.568 - info: cmd finished failure SDKM_END_CODE_FAILURE_711ff1ab-178d-4657-b11a-e29eb18bf938
2019-08-08 20:12:48.568 - error: command terminated with error
2019-08-08 20:12:48.622 - error: install 'Flash Jetson Nano' failure, command < cd '/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP' -v='32.2' -l='/home/suryadi/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448' -L='/home/suryadi/.nvsdkm/logs/JetPack_4.2.1_Linux_GA' -p='28143' -t='P3448-0000' -e='undefined' > terminated with error
How to overcome this problem? Thank you very much in advance.
Warmest Regards,
Suryadi
FYI, force recovery mode temporarily turns the Nano into a custom USB device a Linux PC can understand (after installing JetPack/SDK Manager) and flash (recovery mode itself does not change the Jetson unless flash operations are used). In the case of the Nano dev kit there is no internal hard drive/eMMC, and only the SD card is present, so you might not need recovery mode as often as you would with another model. As an example, the upcoming Nano module which is sold separately will have eMMC, and so there would be no way to flash the eMMC on that unit if there were no recovery mode. Recovery mode works even when there is no o/s.
