[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.132] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.140] Power-up reason: pmc por
[0000.143] No Battery Present
[0000.146] pmic max77620 reset reason
[0000.149] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.155] Platform has DDR4 type RAM
[0000.158] max77620 disabling SD1 Remote Sense
[0000.162] Setting DDR voltage to 1125mv
[0000.166] Serial Number of Pmic Max77663: 0x72de4
[0000.174] Entering ramdump check
[0000.177] Get RamDumpCarveOut = 0x0
[0000.180] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.185] Last reboot was clean, booting normally!
[0000.190] Sdram initialization is successful
[0000.194] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.200] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.206] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.212] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.229] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.235] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.251] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.485] Csd NumOfBlocks=62333952
[0000.490] Set High speed to 1
[0000.494] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.504] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.510] Number of retries left 4
[0000.522] Using GPT Primary to query partitions
[0000.526] Loading Tboot-CPU binary
[0000.539] Verifying TBC in OdmNonSecureSBK mode
[0000.549] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.556] Bootloader downloaded successfully.
[0000.560] Downloaded Tboot-CPU binary to 0xa0000258
[0000.565] MAX77620_GPIO5 configured
[0000.568] CPU power rail is up
[0000.571] CPU clock enabled
[0000.575] Performing RAM repair
[0000.578] Updating A64 Warmreset Address to 0xa00002e9
[0000.583] Loading NvTbootBootloaderDTB
[0000.620] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.685] Bootloader DTB Load Address: 0x83000000
[0000.690] Loading NvTbootKernelDTB
[0000.727] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.791] Kernel DTB Load Address: 0x83100000
[0000.798] Loading cboot binary
[0000.841] Verifying EBT in OdmNonSecureSBK mode
[0000.884] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.891] Bootloader downloaded successfully.
[0000.895] Next binary entry address: 0x92c00258
[0000.900] BoardId: 3448
[0000.904] Overriding pmu board id with proc board id
[0000.909] Display board id is not available
[0000.951] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.003] /bpmp deleted
[0001.005] SC7EntryFw header found loaded at 0xff700000
[0001.194] OVR2 PMIC
[0001.196] Bpmp FW successfully loaded
[0001.201] WB0 init successfully at 0xff780000
[0001.205] Set NvDecSticky Bits
[0001.209] GSC2 address ff53fffc value c0edbbcc
[0001.215] GSC MC Settings done
[0001.220] TOS Image length 53680
[0001.223] Monitor size 53680
[0001.226] OS size 0
[0001.236] Secure Os AES-CMAC Verification Success!
[0001.240] TOS image cipher info: plaintext
[0001.244] Loading and Validation of Secure OS Successful
[0001.260] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.265] NvTbootPackSdramParams: start.
[0001.270] NvTbootPackSdramParams: done.
[0001.274] Tegraboot started after 53949 us
[0001.278] Basic modules init took 881726 us
[0001.282] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0001.287] Sec Bootdevice Read Time = 622327755 ms, Read Size = 622327755 KB
[0001.294] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.299] Storage Device Read Time = 179 ms, Read Size = 2226 KB
[0001.305] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.310] Next stage binary read took 38981 us
[0001.315] Carveout took -50643 us
[0001.318] CPU initialization took 380572 us
[0001.322] Total time taken by TegraBoot 1250636 us
[0001.327] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 16:52:46, Jul 16 2019
ERROR: Error initializing runtime service trusty_fast
[0001.449] RamCode = 0
[0001.453] LPDDR4 Training: Read DT: Number of tables = 2
[0001.458] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.471] EMC Training Successful
[0001.474] 408000 not found in DVFS table
[0001.481] RamCode = 0
[0001.484] DT Write: emc-table@204000 succeeded
[0001.490] DT Write: emc-table@1600000 succeeded
[0001.494] LPDDR4 Training: Write DT: Number of tables = 2
[0001.539]
[0001.540] Debug Init done
[0001.542] Marked DTB cacheable
[0001.545] Bootloader DTB loaded at 0x83000000
[0001.550] Marked DTB cacheable
[0001.553] Kernel DTB loaded at 0x83100000
[0001.557] DeviceTree Init done
[0001.569] Pinmux applied successfully
[0001.573] gicd_base: 0x50041000
[0001.576] gicc_base: 0x50042000
[0001.579] Interrupts Init done
[0001.584] Using base:0x60005090 & irq:208 for tick-timer
[0001.589] Using base:0x60005098 for delay-timer
[0001.593] platform_init_timer: DONE
[0001.597] Timer(tick) Init done
[0001.600] osc freq = 38400 khz
[0001.604]
[0001.606] welcome to cboot
[0001.608]
[0001.609] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.614] calling constructors
[0001.617] initializing heap
[0001.620] initializing threads
[0001.623] initializing timers
[0001.626] creating bootstrap completion thread
[0001.630] top of bootstrap2()
[0001.633] CPU: ARM Cortex A57
[0001.636] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.641] initializing platform
[0001.644] Scratch reg 37 & 271 initial value set…
[0001.650] cboot:secure-pmc present
[0001.653] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.658] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.662] Macronix QSPI chip present
[0001.666] SPI device register
[0001.669] init boot device
[0001.671] allocating memory for boot device(SPI)
[0001.676] registering boot device
[0001.685] sdmmc node status = okay
[0001.688] sdcard instance = 0
[0001.691] sdcard gpio handle 0x56
[0001.694] sdcard gpio pin 0xc9
[0001.697] sdcard gpio flags 0x0
[0001.701] vmmc-supply 0x99
[0001.703] Instance: 0
[0001.705] Allocating memory for context
[0001.709] enabling clock
[0001.711] sd card init
[0001.714] Check card present and stable
[0001.717] Send command 0
[0001.742] Send command 3
[0001.746] Set RCA for the card
[0001.749] Query card specific data by command 9
[0001.756] Parse CSD data
[0001.758] Send command 7
[0001.768] Calling sd device register
[0001.772] Init sdcard
[0001.774] Allocating memory for boot device
[0001.778] Registering user device
[0001.791] Enable APE clock
[0001.794] Un-powergate APE partition
[0001.797] of_register: registering tegra_udc to of_hal
[0001.802] of_register: registering tegra_udc to of_hal
[0001.808] of_register: registering inv20628-driver to of_hal
[0001.813] of_register: registering ads1015-driver to of_hal
[0001.819] of_register: registering lp8557-bl-driver to of_hal
[0001.825] of_register: registering bq2419x_charger to of_hal
[0001.830] of_register: registering cpc to of_hal
[0001.835] of_register: registering bq27441_fuel_gauge to of_hal
[0001.846] gpio framework initialized
[0001.849] of_register: registering tca9539_gpio to of_hal
[0001.855] of_register: registering tca9539_gpio to of_hal
[0001.860] of_register: registering i2c_bus_driver to of_hal
[0001.866] of_register: registering i2c_bus_driver to of_hal
[0001.871] of_register: registering i2c_bus_driver to of_hal
[0001.877] of_register: registering i2c_bus_driver to of_hal
[0001.882] pmic framework initialized
[0001.886] of_register: registering max77620_pmic to of_hal
[0001.891] regulator framework initialized
[0001.895] of_register: registering tps65132_bl_driver to of_hal
[0001.901] initializing target
[0001.907] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.916] fixed regulator driver initialized
[0001.932] initializing OF layer
[0001.935] NCK carveout not present
[0001.939] Skipping dts_overrides
[0001.943] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.959] I2C Bus Init done
[0001.962] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.972] I2C Bus Init done
[0001.975] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.985] I2C Bus Init done
[0001.988] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.998] I2C Bus Init done
[0002.001] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.011] I2C Bus Init done
[0002.014] of_children_init: Ops found for compatible string maxim,max77620
[0002.024] max77620_init using irq 118
[0002.029] register ‘maxim,max77620’ pmic
[0002.033] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.039] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.049] I2C Bus Init done
[0002.053] NCK carveout not present
[0002.056] shim_invoke: No NCT, Calling dts updates
[0002.067] Find /i2c@7000c000’s alias i2c0
[0002.071] get eeprom at 1-a0, size 256, type 0
[0002.080] Find /i2c@7000c500’s alias i2c2
[0002.084] get eeprom at 3-a0, size 256, type 0
[0002.088] get eeprom at 3-ae, size 256, type 0
[0002.093] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.098] I2C slave not started
[0002.101] I2C write failed
[0002.104] Writing offset failed
[0002.107] eeprom_init: EEPROM read failed
[0002.111] pm_ids_update: eeprom init failed
[0002.115] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.145] pm_ids_update: The pm board id is 3448-0000-200
[0002.152] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.159] pm_ids_update: pm id update successful
[0002.164] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.169] I2C slave not started
[0002.172] I2C write failed
[0002.175] Writing offset failed
[0002.178] eeprom_init: EEPROM read failed
[0002.182] pm_ids_update: eeprom init failed
[0002.212] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.218] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.226] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.232] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.240] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e4:11:e8
[0002.247] Plugin Manager: Parse ODM data 0x00094000
[0002.256] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTHS1,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.278] Find /i2c@7000c000’s alias i2c0
[0002.282] get eeprom at 1-a0, size 256, type 0
[0002.290] Find /i2c@7000c500’s alias i2c2
[0002.294] get eeprom at 3-a0, size 256, type 0
[0002.299] get eeprom at 3-ae, size 256, type 0
[0002.303] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.308] I2C slave not started
[0002.311] I2C write failed
[0002.314] Writing offset failed
[0002.317] eeprom_init: EEPROM read failed
[0002.321] pm_ids_update: eeprom init failed
[0002.325] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.355] pm_ids_update: The pm board id is 3448-0000-200
[0002.362] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.369] pm_ids_update: pm id update successful
[0002.373] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.379] I2C slave not started
[0002.382] I2C write failed
[0002.384] Writing offset failed
[0002.387] eeprom_init: EEPROM read failed
[0002.391] pm_ids_update: eeprom init failed
[0002.421] Chip UID is 000000016441b744100000000a050340
[0002.426] Add serial number:04212190231000400305 as DT property
[0002.435] Applying platform configs
[0002.441] platform-init is not present. Skipping
[0002.446] calling apps_init()
[0002.465] Found 14 GPT partitions in “sd0”
[0002.469] Proceeding to Cold Boot
[0002.473] starting app android_boot_app
[0002.476] Device state: unlocked
[0002.480] display console init
[0002.488] could not find regulator
[0002.491] hdmi cable connected
[0002.494] I2C slave not started
[0002.497] I2C write failed
[0002.500] Writing offset failed
[0002.503] could not read edid
[0002.509] tmds-config node not found
[0002.513] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.529] DT entry for leds-pwm not found
[0002.533] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.541] could not find regulator
[0002.544] could not find regulator
[0002.547] could not find regulator
[0002.575] using default cmu settings
[0002.579] dc_hdmi_enable, starting HDMI initialisation
[0002.586] dc_hdmi_enable, HDMI initialisation complete
[0002.591] list and configure display window
[0002.595] display console init completed
[0002.603] subnode volume_up is not found !
[0002.606] subnode back is not found !
[0002.610] subnode volume_down is not found !
[0002.614] subnode menu is not found !
[0002.618] Gpio keyboard init success
[0002.663] found decompressor handler: lz4-legacy
[0002.678] decompressing blob (type 1)…
[0002.711] load_bmp_blob: panelresolution=480 type=0
[0002.764] decompressor handler not found
[0002.768] load_firmware_blob: Firmware blob loaded, entries=2
[0002.773] se_aes_verify_sbk_clear: Error
[0002.777] bl_battery_charging: connected to external power supply
[0002.784] xusb is supported
[0002.790] error while finding nvidia,portmap
[0002.796] could not find regulator
[0003.299] xusb blob version 0 size 124416
[0003.303] firmware size 124416
[0003.308] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.316] xhci0: 64 bytes context size, 32-bit DMA
[0003.356] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.376] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.026] uhub0: 9 ports with 9 removable, self powered
[0005.026] failed to get HID devices
[0005.029] failed to init xhci or no usb device attached
[0008.037] Power button long press detected
[0008.041] Entering fastboot mode…
[0008.044] starting fastboot mode
[0008.048] fastboot cmd_init done.
[0008.052] platform does not support off-mode-charge
[0008.056] usbdcd_init Initialize USBF driver
[0008.061] usbdcd_phy_open oscfreq = 5
[0008.070] usbdcd_start Start the initialized controller
[0008.076] get_fastb-- suspend –
o[0008.079] ot_instructions: Error -2 finding instructions in /chosen
[0008.101] Key Code 8 not handled
[0008.304] Key Code 8 not handled
[0008.507] Key Code 8 not handled
