Power Consumption measurement during training
I would like to measure the CPU/GPU (POM_5V_CPU/POM_5V_GPU) power consumption while training a machine learning model on the Jetson Nano (P3450). I am using the tegrastats utility with this command:
sudo tegrastats --interval 1000 > tegra_dump.log
Two questions:
  1. When using the --interval 1000 flag, does this mean that the second value reported is the average current over the 1000 ms?
  2. Is there a better/recommended way to measure power consumption
Related forum posts:
Hi ali.jahangiri,
Are you using the devkit or custom board for Jetson Nano?
Correct, it is indeed the average readings over that 1000ms interval.
Maybe you can also try using jtop tool.
$ sudo -H pip install -U jetson-stats
Or read from sysfs node as following:
$ cat /sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/in_power0_input
Yes, I am using the original Devkit
Would the Power Monitor Information be the part of the NVIDIA Jetson Linux Developer Guide I should refer to on how to access the INA3221 readings?
Thanks Kevin!
Yes, you can refer to that part for those readings.
