Power consumption of AGX Orin SOM
We can see that AGX Orin 32GB SOM supports following modes 15W, 30W, 40W and MAXN.
What would be the maximum power consumption by the AGX Orin Module in the MAXN mode and the current consumption in each voltage domain?
We can see in the datasheet that the maximum current is limited at 5.4 A and 6 A for SYS_VIN_HV(20V) and SYS_VIN_MV(5V) domains respectively. Does the current value can reach up to these maximum limits during operation in MAXN mode?
Hi, same as your other topic, JAO 32GB Maximum Module Power: Up to 40W. The maximum current limit is for safety. The system will throttle performance when power consumption reach 40W.
