I saw that it was written in the manual that it was 5@15W, and I understood that this 15W should be the power consumption of all hardware interfaces running, because there are not so many interfaces used in actual use, and if it is designed according to 15W, it is too redundant。
I’d like to ask if there is a detailed power manual;
No such manual can be shared.15W is the max power of module, not whole devkit or custom design. The real power consumption depends on use case. The simple way is to use 15W as the design threshold.
