I am measuring the GPU power on the TX1 through the INA monitors available in the newer revisions. Would like to know if the 15W limit envelope is statically fixed between the GPU, CPU and Memory or is it dynamic in the sense that if there is no load on CPU then the GPU can boost up to as much as required. Reason I am asking is that in some benchmarks I am using the GPU power goes up to 7 or 8 watt at times. I hope this information can be discussed here. Thank you.
Best,
Trinayan
