We use Orin NX Advanced Module and supply 12V to VDD _IN. The designed carrier board does not have a 5V voltage source, but have a 12V voltage source. I want to connect a resistor and a zener diode to provide a 5V level for POWER_EN Pin, whether it will work?
Not sure about your design, but for POWER_EN, it would be ok if the voltage level is correct.
