Power Mode VIC frequency
Is it possible to configure the VIC min/ max frequency through a power mode configuration file, or would a separate script have to be run at boot? The only reference I can see in the documentation is just the default maximum speed.
Hi teebr,
VIC frequency could not be configured from nvpmodel config.
You could refer to the following instruction to configure it through sysfs for VIC frequency.
Clocks — Setting the Static VIC Frequency
Thanks for confirming Kevin.
