Power modes on Orin Nano
I get no performance changes by changing the power modes on Orin Nano running Jetpack 7.2. I ran a python script that uses GPU and it took the same amount of time across all the power modes (15W, 25W and MAXN). I changed the power modes by running sudo nvpmodel -m 0/1/2.
Please provide the python scripts so we could reproduce in our side.
import numpy as np
from numba import cuda, int32
import time
BSP2 = 9
BLOCK_SIZE = 2**BSP2
#CUDA kernel to calculate prefix sum of each block of input array
@cuda.jit('void(int32[:], int32[:], int32[:], int32, int32)')
def prefix_sum_nzmask_block(a, b, s, nzm, length):
    ab = cuda.shared.array(shape=(BLOCK_SIZE), dtype=int32)
    tid = cuda.blockIdx.x * cuda.blockDim.x + cuda.threadIdx.x;
    ab[cuda.threadIdx.x] = 0
    if tid < length:
        if nzm == 1:
            ab[cuda.threadIdx.x] = int32(a[tid] != 0); #Load mask of input data into shared memory
        else:
            ab[cuda.threadIdx.x] = int32(a[tid]); #Load input data into shared memory
    for j in range(0,BSP2):
        i = 2**j
        cuda.syncthreads()
        if i <= cuda.threadIdx.x:
            temp = ab[cuda.threadIdx.x]
            temp += ab[cuda.threadIdx.x - i] #Perform scan on shared memory
        cuda.syncthreads()
            ab[cuda.threadIdx.x] = temp
    if tid < length:
        b[tid] = ab[cuda.threadIdx.x]; #Write scanned blocks to global memory
    if(cuda.threadIdx.x == cuda.blockDim.x-1):  #Last thread of block
        s[cuda.blockIdx.x] = ab[cuda.threadIdx.x]; #Write last element of shared memory into global memory
#CUDA kernel to merge the prefix sums of individual blocks
@cuda.jit('void(int32[:], int32[:], int32)')
def pref_sum_update(b, s, length):
    tid = (cuda.blockIdx.x + 1) * cuda.blockDim.x + cuda.threadIdx.x; #Skip first block
    if tid<length:
        b[tid] += s[cuda.blockIdx.x] #Accumulate last elements of all previous blocks
#CUDA kernel to copy non-zero entries to the correct index of the output array
@cuda.jit('void(int32[:], int32[:], int32[:], int32)')
def map_non_zeros(a, prefix_sum, nz, length):
    if tid < length:
        input_value = a[tid]
        if input_value != 0:
            index = prefix_sum[tid] #The correct output index is the value at current index of prefix sum array
            nz[index-1] = input_value
#Apply stream compaction algorithm to get only the non-zero entries from the input array
def pref_sum(a, asum, nzm):
    block = BLOCK_SIZE
    length = a.shape[0]
    grid = int((length + block -1)/block)
    #Create auxiliary array to hold the sum of each block
    bs = cuda.device_array(shape=(grid), dtype=np.int32)
    #Perform partial scan of each block. Store block sum in auxillary array named block_sum.
    prefix_sum_nzmask_block[grid, block](a, asum, bs, nzm, length)
    if grid > 1:
        bssum = cuda.device_array(shape=(grid), dtype=np.int32)
        pref_sum(bs, bssum, 0)
        pref_sum_update[grid-1, block](asum, bssum, length)
def get_non_zeros(a):
    #Copy input array from host to device
    ad = cuda.to_device(a)
    #Create prefix sum output array
    bd = cuda.device_array_like(ad)
    pref_sum(ad, bd, int(1))
    #The last element of prefix sum contains the total number of non-zero elements
    non_zero_count = int(bd[bd.shape[0]-1])
    #Create device output array to hold ONLY the non-zero entries
    non_zeros = cuda.device_array(shape=(non_zero_count), dtype=np.int32)
    #Copy ONLY the non-zero entries
    block = BLOCK_SIZE
    length = a.shape[0]
    map_non_zeros[grid, block](ad, bd, non_zeros, length)
    #Return to host
    return non_zeros.copy_to_host()
if __name__ == '__main__':
    arr = np.zeros(500000000, dtype=np.int32)
    for i in range(32,65000, 1024):
        arr[i] = i
    start_time=time.time()
    nz = get_non_zeros(arr)
    print(nz)
    print("time elapsed=",time.time()-start_time,"s")
The above code takes approx. 2 seconds to run on Orin Nano in all the three power modes.
Also, all CPU cores are running on all power modes as per jtop utility.
Thanks,
Please run sudo jetson_clocks and run your scripts again.
Please also provide below result
grep -E 'EMC|GPU' /etc/nvpmodel.conf
Running grep -E 'EMC|GPU' /etc/nvpmodel.conf gives,
(python3-venv) ps_nithin@orin-nano:~$ grep -E 'EMC|GPU' /etc/nvpmodel.conf
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_ENABLE >
GPU_PWR_CNTL_EN /sys/devices/gpu.0/power/control
GPU_PWR_CNTL_EN_KNEXT /sys/devices/platform/gpu.0/power/control
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_DISABLE >
GPU_PWR_CNTL_DIS /sys/devices/gpu.0/power/control
GPU_PWR_CNTL_DIS_KNEXT /sys/devices/platform/gpu.0/power/control
< PARAM TYPE=CLOCK NAME=GPU >
<PARAM TYPE=CLOCK NAME=EMC >
GPU_POWER_CONTROL_ENABLE GPU_PWR_CNTL_EN on
GPU MIN_FREQ 0
GPU MAX_FREQ 612000000
GPU_POWER_CONTROL_DISABLE GPU_PWR_CNTL_DIS auto
EMC MAX_FREQ 2133000000
GPU MIN_FREQ 0
GPU MAX_FREQ 918000000
EMC MAX_FREQ 3199000000
GPU MIN_FREQ 0
GPU MAX_FREQ -1
EMC MAX_FREQ -1
Running sudo jetson_clocks slightly improves performance but the performance remains same across 3 power modes.
The measured power consumption is approx. 15W in all the three modes.
Found the same issue in the forums. But the solutions didn’t work out for me. Not sure if I am doing something incorrectly. Measured power consumption is still at ~15w. Is there an official guide on how to enable 25w/MAXN on orin nano running jp7.2.
Thanks,
Please refer to the developer guide and flash with jetson-orin-nano-devkit-super config.
Hi @DavidDDD ,
Following the guide i was able to successfully enable super config.
I measured the actual power consumption after enabling super config. In my case the power consumption does not increase above 15-16W even after enabling 25W or MAXN_SUPER. Why is it so?
Thanks,
