Power Requirement for Jetson TX2 Development Board
https://developer.download.nvidia.com/assets/embedded/secure/jetson/TX2/docs/NVIDIA_Jetson_TX1_and_TX2_Voltage_and_Current_Monitor_Configuration.pdf?qlUnYgBiPunmRv2-dICzkAU3wk_9G9zCw97EjTaLmCpSbUhiTv2rLSkiylJH6KjXr9Ur_MqtSAB6ea-uKZUHhQ_3YZRtYRw5vzFGFVjA1ZjLenkODGpgRLt-vq8p7BDnTfesFwwae16w3VqxTtfFKia_IIHp1fQNTEBRvVd6O8U64jRSKlZxqhE8hda_5SiaokfOBZf-2ASoSRfKmS0fJZUYRvtf3dwFKA1qcGo
uno puede regular la entrada de voltaje desde la tarjeta, es decir, Trabaja con 19 V y la corriente puede llegar hasta los 8,1 amperios
pero hacen el calculo para 40w. Se puede utilizar un voltaje menor pero hay que calcular la corriente critica
eso lo puedes programar en la tarjeta y listo
Hi yennyromero.95,
Welcome to Jetson & Embedded Systems developer forum.
Please create the topic and issue in English manner.
Other developers can understand your issue and to share their experience with you quickly if they ever met similar issue in design stage.
And then other users could be leverage from this issue to get benefits.
Thank you.
