Power supply 5V-4A on Jetson Nano IO Base A
Hi everyone, how to use power supply 5V-4A on my Jeson Nano IO Base A when my carrier board doesn’t have barrel jack j48 (I use adapter 5V-4A).
Which board do you mean? Is it P3449? The J48 on P3449 is a jumper header not barrel jack. Anyway, you should be able to find out answer by checking the carrier board schematic in DLC.
