I was considering using my odroid xu4 barrel power supply on this device, its 5v 6a with centre positive pin. my understanding of amperage is that this should be ok because the nano wont pull more amps than it requires, and should not pull more than 4, am I correct in this assumption?
Yes 6A@5V should be OK to supply Nano devkit.
thank you
