I am working on a project which is planned to be used in cars, It makes object detection and gives advice.
The programming part is almost done, I have trained my model and test it on videos in my home, however, I want to plug it into my car output to test it in real life.
What could you suggest to achieve this goal?
Please give me advice, I am really afraid to destroy my Device with any short circuit.
Hi, Jetson Nano is limited to 5V input, you need a level shift/converter to make the 12V to 5V, it is easy to get which is just like the 12v to USB output for charging mobile phone.
And can you advise how many Amere the Nano will need if I intend to place ‘heavy load’ of commuting it. I understand I need 5v but a bit worried about the Amperes.
Thank you.
Idk details as i am not a electrician however you should at least have 10W DC power, because of Nano uses 5V input, the ampere should is 2 from the formula W = A x V
12 Mar 2021 Cum 12:51 tarihinde Yoav El via NVIDIA Developer Forums <nvidia@discoursemail.com> şunu yazdı:
