Powering AGX Xavier with USB-C PD?
As far as I know, the Xavier can be powered with either DC barrel jack or USB-Type C port
The 19V barrel jack works flawlessly but when I tried to power through 36W type-C powerbank, the Xavier shutdown at bootscreen or even won’t boot up anything. Changing the power scheme to 10W mode won’t help either.
What can I do ?
Hi, can the board boot up with 19V barrel jack supply after this? If it can boot up, then the board has no problem, and then can you try other more powerful than 36W powerbank?
