Powering Jetson Orin Nano via PoE. What are my options?
Hi everyone,
I’m currently running a computer vision pipeline (RGB-D camera + YOLO inference) on a Raspberry Pi 5, powered via PoE using an industrial PoE splitter. I’m planning to migrate the processing to a Jetson Orin Nano to run the workload on the edge, and I’d like to keep the same PoE infrastructure since the device will be deployed in a location without easy access to a standard power outlet.
A few questions:
  1. Is it possible to power the Jetson Orin Nano directly from a PoE splitter?
  2. Are there any PoE HATs or adapters specifically designed for the Jetson Orin Nano? I’ve seen some third-party solutions, but I’m not sure if any of them are compatible with the Orin Nano form factor.
  3. What is the recommended minimum PoE wattage? My workload involves a USB3 RGB-D camera (Orbbec Gemini 335L) and continuous GPU inference at ~15 fps. I’ve had undervoltage issues on the RPi5 under similar conditions, so I want to make sure I provision enough headroom.
  4. Any known caveats or community experiences powering an Orin Nano via PoE in a long-term deployment?
Thanks in advance — any advice from people who have done this in the field would be really helpful!
Setup context:
  • Jetson Orin Nano Developer Kit (8GB)
  • Orbbec Gemini 335L camera (USB 3.2)
  • PoE injector: IEEE 802.3at/bt compatible
  • Deployment: outdoor/remote location
Refer to Jetson Orin Nano Series Modules Data Sheet for max power.
If you have a specific use case, you can check the power consumption with Tegrastats while the use case is running.
NV does not have a reference or guide lines for PoE power supply.
