Hi all,
Is it fine to power the Jetson TX2 with RAVPower rp-pb14 (https://www.ravpower.com/downloads-RP-PB14.html).
I searched on the forum that this battery bank is able to power TX-1 Dev board.
https://devtalk.nvidia.com/default/topic/974064/dc-jack-specs-larger-goal-powering-the-dev-kit-with-a-battery-/?offset=4
As I look into the specification of the bank, it can output the voltage of 9V/ 12V/ 16V/ 19V/ 20V at max 4.5A.
However, as I read on the Jetson TX-2 dev kit the power rating is 5.5.V DC: 14.5A ~ 19.6VDC: 4.74A.
At 19.6V ==> 4.74A which is higher than the bank capability.
Thank you,
