PPS drivers not installing
I’m encountering difficulties with installing the PPS driver. Here are the steps I’ve taken so far:
I installed Linux source codes using the command: sudo apt-get source linux
I included PPS in the kernel configuration by modifying .config as follows:
CONFIG_HSI_CHAR=m
CONFIG_PPS=m
CONFIG_PPS_DEBUG=y
PPS clients support
CONFIG_PPS_CLIENT_KTIMER=m
CONFIG_PPS_CLIENT_LDISC=m
CONFIG_PPS_CLIENT_PARPORT=m
CONFIG_PPS_CLIENT_GPIO=m
I executed sudo make drivers/pps/ to generate pps-ktimer.o.
Upon trying to load the module with sudo modprobe pps-ktimer, I encountered the following error:
modprobe: ERROR: could not insert 'pps_ktimer': Exec format error
Despite having the latest version of the driver installed, I’m unable to utilize modprobe, which prevents me from running the ppstest codes mentioned in the documentation here.
I encounter the following error when running
./ppstest /dev/pps1:
trying PPS source "/dev/pps1"
unable to open device "/dev/pps1" (No such file or directory)
Any guidance on resolving this issue would be greatly appreciated. Thank you!
