Ppstest time_pps_fetch() error -1 (Connection timed out)
agx orin jp5.1.1 Self-defined board自定板子
ppstest /dev/pps0
trying PPS source "/dev/pps0"
found PPS source "/dev/pps0"
ok, found 1 source(s), now start fetching data...
source 0 - assert 1698848726.442950344, sequence: 19191 - clear  0.000000000, sequence: 0
ppstest /dev/pps1
trying PPS source "/dev/pps1"
found PPS source "/dev/pps1"
However, the PPS interrupt can be acquired and the counter increments, indicating that the system has successfully obtained the interrupt.
但是中断能获取到pps中断,并且会递增,说明系统已经获取到中断:
Here is the patch for PPS modification:
如下是pps修改的补丁:
diff --git a/Linux_for_Tegra/source/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0004-p3737-0000.dts b/Linux_for_Tegra/source/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0004-p3737-0000.dts
index 132fd345c..3d8e4e270 100644
--- a/Linux_for_Tegra/source/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0004-p3737-0000.dts
+++ b/Linux_for_Tegra/source/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0004-p3737-0000.dts
@@ -68,6 +68,13 @@
 		status = "okay";
+	pps {
+		gpios = <&tegra_main_gpio TEGRA234_MAIN_GPIO(Q, 2) GPIO_ACTIVE_LOW>;
+		compatible = "pps-gpio";
+		assert-falling-edge;
+		status = "okay";
 	bpmp {
 		i2c {
 			tegra_tmp451: temp-sensor@4c {
diff --git a/Linux_for_Tegra/source/kernel/kernel-5.10/arch/arm64/configs/defconfig b/Linux_for_Tegra/source/kernel/kernel-5.10/arch/arm64/configs/defconfig
index c8a215f95..5421a7e1c 100644
--- a/Linux_for_Tegra/source/kernel/kernel-5.10/arch/arm64/configs/defconfig
+++ b/Linux_for_Tegra/source/kernel/kernel-5.10/arch/arm64/configs/defconfig
@@ -754,8 +754,11 @@ CONFIG_SPI_ZYNQMP_GQSPI=m
 CONFIG_SPI_SPIDEV=m
 CONFIG_SPI_TLE62X0=m
 CONFIG_SPMI=m
+CONFIG_PPS=y
 CONFIG_PPS_DEBUG=y
-CONFIG_PPS_CLIENT_GPIO=y
+CONFIG_PPS_CLIENT_KTIMER=y
+CONFIG_PPS_CLIENT_LDISC=y
+CONFIG_PPS_CLIENT_GPIO=m
 CONFIG_PINCTRL_TEGRA186_DPAUX=y
 CONFIG_PINCTRL_TEGRA234_DPAUX=y
 CONFIG_PINCTRL_SINGLE=y
Please help check why ppstest /dev/pps1 is reporting an error. Thank you.
帮忙看一下为什么ppstest /dev/pps1会报错,谢谢
hello 252830387,
according to your code snippets, it’s assert on the falling-edge of signal.
since it shows connection has timed out.
may I know what’s your hardware setups? did you have continuous PPS signal attached?
besides,
you may see-also developer guide, Using the Pins in GPIO Mode to double check you’re using correct pin.
GPIO_ACTIVE_LOW ->GPIO_ACTIVE_HIGH
