I use nvivafilter to access the NVMM buffers. There are something in the pre_process() function that I don’t understand.
My image format is NV12. How do NV12 is store in the buffer? How do a make a pixel black?
Is there any documentations that you recommend? (I’m a newbie to this stuff)
Thank you.
Please refer to the README:
2. Image processing APIs
a. Pre-/Post- processing
i. input parameters:
void ** sBaseAddr : mapped pointers array point to different
plane of image.
unsigned int * smemsize : actually allocated memory size array for
each image plane, no less than plane
width * height.
unsigned int * swidth : width array for each image plane
unsigned int * sheight : height array for each image plane
unsigned int * spitch : actual line width array in memory for
width
ColorFormat * sformat : color format array, i.e.,
* NV12 image will have:
sformat[0] = COLOR_FORMAT_Y8
sformat[1] = COLOR_FORMAT_U8_V8
* RGBA image will have:
sformat[0] = COLOR_FORMAT_RGBA
unsigned int nsurfcount : number of planes of current image type
void ** userPtr : point to customer allocated buffer in
processing function
ii. output parameters:
none
Is there any tool to convert a .png file to RGBA format array?
You would need to decode png through software decoder and then convert to RGBA. May try gstreamer pipeline like:
Problem with opening png sequence by gstreamer and nvvidconv - #2 by DaneLLL
Is possible to pass arguments from gstreamer pipeline to pre_process() function?
I put my pre_process() function below. I noticed that if the pipeline was left running for about 15 minutes, the jetson became very slow. Can you recommend what I should do to speed up the code? Thanks
static void
pre_process (void **sBaseAddr,
unsigned int *smemsize,
unsigned int *swidth,
unsigned int *sheight,
unsigned int *spitch,
ColorFormat *sformat,
unsigned int nsurfcount,
void ** usrptr)
if (sformat[0] == COLOR_FORMAT_RGBA) {
cairo_surface_t *surface, *mask_surface;
cairo_t *cairo_context;
surface = cairo_image_surface_create_for_data
((unsigned char *)sBaseAddr[0], CAIRO_FORMAT_ARGB32, swidth[0],
sheight[0], spitch[0]);
cairo_context = cairo_create (surface);
mask_surface = cairo_image_surface_create_from_png("Square_Mask_v2p00.png");
cairo_set_source_surface(cairo_context, mask_surface, 0.0, 0.0);
cairo_paint(cairo_context);
cairo_destroy (cairo_context);
cairo_surface_destroy (surface);
Please run $ sudo nvpmodel -m 0 and $ sudo jetson_clocks to run CPU cores at maximum clock. This shall bring optimal perofrmance.
And please run $ sudo jetson_clocks to check system status. Probably the system has hit thermal condition and gets slow.
