I have a sensor that produces a high signal on detecting a corrugated board. The output signal of the sensor is connected as an input to the NVIDIA Xavier GPIO unit. I read the signal in the code and start the capture request using Argus. My camera does not have an external hardware trigger for capturing. My questions are,
Is there a way to do precise triggering for capturing images from the cameras. I’m expecting a latency of less than 60 microseconds.
Are there any external FPGA boards to do these kind of precise triggering?
What is the maximum latency time that I can expect for the aforementioned process in Xavier? (Sensor - GPIO - Capture Request (Argus))
hello sathish.nitt76,
you’ll also need to consider the sensor frame-rate, suppose you’re working with a 30-fps sensor. you should expect there’s 33ms to issue a capture request.
besides, please also note that, there’s ring buffers to queue captured frames,
please also refer to below kernel source, it’ll release buffer N at N+2 frame start event.
for example,
<i>$l4t-r32.3.1/JAX_TX2/Linux_for_Tegra/source/public/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/vi/channel.c</i>
void tegra_channel_ring_buffer(struct tegra_channel *chan,
struct vb2_v4l2_buffer *vb,
struct timespec *ts, int state)
/* release buffer N at N+2 frame start event */
if (chan->num_buffers >= (chan->capture_queue_depth - 1))
free_ring_buffers(chan, 1);
please also contact with Jetson Preferred Partners for camera solutions,
thanks
