Preparing fasterrcnn model to deploy at deepstream trained with Tao
• Hardware Platform (Jetson / GPU) Jetson Orin nano
• DeepStream Version 6.4
• JetPack Version (valid for Jetson only) 6.0
I am following discussion here to deploy fasterrcnn at Deepstream.
I have downloaded TensorRT and build as
git clone -b 23.08 https://github.com/nvidia/TensorRT
cd TensorRT/
git submodule update --init --recursive
export TRT_SOURCE=`pwd`
cd $TRT_SOURCE
mkdir -p build && cd build
Then
/usr/local/bin/cmake .. -DGPU_ARCHS=72  -DTRT_LIB_DIR=/usr/lib/aarch64-linux-gnu/ -DCMAKE_C_COMPILER=/usr/bin/gcc -DTRT_BIN_DIR=`pwd`/out
Is -DGPU_ARCHS=72? Because there is no architecture mentioned for Orin.
When run the command
make nvinfer_plugin -j$(nproc)
I have errors as follows. How to solver?
[ 94%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/sortScoresPerClass.cu.o
[ 94%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/sortScoresPerImage.cu.o
[ 94%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/voxelGeneratorKernels.cu.o
[ 94%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/bertQKVToContextPlugin/qkvToContext.cu.o
[ 94%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/bertQKVToContextPlugin/zeroPadding2d.cu.o
[ 97%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/embLayerNormPlugin/embLayerNormKernel.cu.o
/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/bertQKVToContextPlugin/qkvToContext.cu(137): warning #20054-D: dynamic initialization is not supported for a function-scope static __shared__ variable within a __device__/__global__ function
      __attribute__((shared)) SMem tmp;
          detected during:
            instantiation of "void nvinfer1::plugin::bert::softmax<T,TPB,VPT>(float, const T *, T *) [with T=float, TPB=128, VPT=4]" at line 230
            instantiation of "int32_t nvinfer1::plugin::bert::computeScaledSoftmax(cudaStream_t, int32_t, int32_t, int32_t, float, const T *, T *) [with T=float]" at line 591
Remark: The warnings can be suppressed with "-diag-suppress <warning-number>"
          detected during:
            instantiation of "void nvinfer1::plugin::bert::softmax<T,TPB,VPT>(float, const T *, T *) [with T=float, TPB=384, VPT=4]" at line 236
          detected during:
            instantiation of "void nvinfer1::plugin::bert::softmax<T,TPB,VPT>(float, const T *, T *) [with T=half, TPB=128, VPT=8]" at line 230
            instantiation of "int32_t nvinfer1::plugin::bert::computeScaledSoftmax(cudaStream_t, int32_t, int32_t, int32_t, float, const T *, T *) [with T=half]" at line 564
          detected during:
            instantiation of "void nvinfer1::plugin::bert::softmax<T,TPB,VPT>(float, const T *, T *) [with T=half, TPB=384, VPT=8]" at line 236
/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/bertQKVToContextPlugin/qkvToContext.cu(55): warning #20054-D: dynamic initialization is not supported for a function-scope static __shared__ variable within a __device__/__global__ function
          detected during:
            instantiation of "void nvinfer1::plugin::bert::maskedSoftmax<T,TPB,VPT>(float, const T *, T *, const int *) [with T=float, TPB=128, VPT=1]" at line 307
            instantiation of "int32_t nvinfer1::plugin::bert::computeMaskedScaledSoftmax(cudaStream_t, int32_t, int32_t, int32_t, float, const int32_t *, const T *, T *) [with T=float]" at line 587
          detected during:
            instantiation of "void nvinfer1::plugin::bert::maskedSoftmax<T,TPB,VPT>(float, const T *, T *, const int *) [with T=float, TPB=128, VPT=4]" at line 314
          detected during:
            instantiation of "void nvinfer1::plugin::bert::maskedSoftmax<T,TPB,VPT>(float, const T *, T *, const int *) [with T=float, TPB=384, VPT=1]" at line 324
          detected during:
            instantiation of "void nvinfer1::plugin::bert::maskedSoftmax<T,TPB,VPT>(float, const T *, T *, const int *) [with T=float, TPB=384, VPT=4]" at line 331
          detected during:
            instantiation of "void nvinfer1::plugin::bert::maskedSoftmax<T,TPB,VPT>(float, const T *, T *, const int *) [with T=half, TPB=128, VPT=2]" at line 307
            instantiation of "int32_t nvinfer1::plugin::bert::computeMaskedScaledSoftmax(cudaStream_t, int32_t, int32_t, int32_t, float, const int32_t *, const T *, T *) [with T=half]" at line 560
          detected during:
            instantiation of "void nvinfer1::plugin::bert::maskedSoftmax<T,TPB,VPT>(float, const T *, T *, const int *) [with T=half, TPB=128, VPT=8]" at line 314
          detected during:
            instantiation of "void nvinfer1::plugin::bert::maskedSoftmax<T,TPB,VPT>(float, const T *, T *, const int *) [with T=half, TPB=384, VPT=2]" at line 324
          detected during:
            instantiation of "void nvinfer1::plugin::bert::maskedSoftmax<T,TPB,VPT>(float, const T *, T *, const int *) [with T=half, TPB=384, VPT=8]" at line 331
/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormKernel.cu(228): error: no instance of function template "cuda::std::__4::plus<void>::operator()" matches the argument list
            argument types are: (cub::CUB_200200_720_NS::KeyValuePair<float, float>, cub::CUB_200200_720_NS::KeyValuePair<float, float>)
            object type is: cub::CUB_200200_720_NS::Sum
              threadData = pairSum(threadData, kvp<T>(rldval, rldval * val));
          detected during:
            instantiation of "void nvinfer1::plugin::bert::embLayerNormKernel<T,TPB>(int, const int32_t *, const int32_t *, const float *, const float *, const T *, const T *, const T *, int32_t, int32_t, T *) [with T=float, TPB=256U]" at line 247
            instantiation of "int32_t nvinfer1::plugin::bert::embSkipLayerNorm(cudaStream_t, int32_t, int32_t, int32_t, const int32_t *, const int32_t *, const float *, const float *, const T *, const T *, const T *, int32_t, int32_t, T *) [with T=float]" at line 253
/usr/local/cuda-12.2/include/cub/warp/specializations/warp_reduce_shfl.cuh(360): error: no instance of function template "cuda::std::__4::plus<void>::operator()" matches the argument list
              output = reduction_op(input, temp);
          detected during:
            instantiation of "_T cub::CUB_200200_720_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::ReduceStep(_T, ReductionOp, int, int) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, _T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, ReductionOp=cub::CUB_200200_720_NS::Sum]" at line 388
            instantiation of "_T cub::CUB_200200_720_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::ReduceStep(_T, ReductionOp, int, int, cub::CUB_200200_720_NS::Int2Type<0>) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, _T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, ReductionOp=cub::CUB_200200_720_NS::Sum]" at line 403
            instantiation of "void cub::CUB_200200_720_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::ReduceStep(T &, ReductionOp, int, cub::CUB_200200_720_NS::Int2Type<STEP>) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, ReductionOp=cub::CUB_200200_720_NS::Sum, STEP=0]" at line 449
            instantiation of "T cub::CUB_200200_720_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::ReduceImpl(cub::CUB_200200_720_NS::Int2Type<1>, T, int, ReductionOp) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, ReductionOp=cub::CUB_200200_720_NS::Sum]" at line 530
            instantiation of "T cub::CUB_200200_720_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::Reduce<ALL_LANES_VALID,ReductionOp>(T, int, ReductionOp) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, ALL_LANES_VALID=true, ReductionOp=cub::CUB_200200_720_NS::Sum]" at line 204 of /usr/local/cuda-12.2/include/cub/block/specializations/block_reduce_warp_reductions.cuh
            instantiation of "T cub::CUB_200200_720_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::Reduce<FULL_TILE,ReductionOp>(T, int, ReductionOp) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_720_NS::Sum]" at line 354 of /usr/local/cuda-12.2/include/cub/block/block_reduce.cuh
            instantiation of "T cub::CUB_200200_720_NS::BlockReduce<T, BLOCK_DIM_X, ALGORITHM, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::Reduce(T, ReductionOp) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, ALGORITHM=cub::CUB_200200_720_NS::BLOCK_REDUCE_WARP_REDUCTIONS, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, ReductionOp=cub::CUB_200200_720_NS::Sum]" at line 257 of /opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/common/common.cuh
            instantiation of "void layerNorm<T,R,P,TPB>(const kvp<R> &, int32_t, int32_t, const P *, const P *, T *) [with T=float, R=float, P=float, TPB=256]" at line 233 of /opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormKernel.cu
            instantiation of "void nvinfer1::plugin::bert::embLayerNormKernel<T,TPB>(int, const int32_t *, const int32_t *, const float *, const float *, const T *, const T *, const T *, int32_t, int32_t, T *) [with T=float, TPB=256U]" at line 247 of /opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormKernel.cu
            instantiation of "int32_t nvinfer1::plugin::bert::embSkipLayerNorm(cudaStream_t, int32_t, int32_t, int32_t, const int32_t *, const int32_t *, const float *, const float *, const T *, const T *, const T *, int32_t, int32_t, T *) [with T=float]" at line 253 of /opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormKernel.cu
/usr/local/cuda-12.2/include/cub/block/specializations/block_reduce_warp_reductions.cuh(119): error: no instance of function template "cuda::std::__4::plus<void>::operator()" matches the argument list
              warp_aggregate = reduction_op(warp_aggregate, addend);
          detected during:
            instantiation of "T cub::CUB_200200_720_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_720_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_720_NS::Sum, SUCCESSOR_WARP=1]" at line 156
            instantiation of "T cub::CUB_200200_720_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp>(ReductionOp, T, int) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_720_NS::Sum]" at line 207
          detected during:
            instantiation of "T cub::CUB_200200_720_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_720_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_720_NS::Sum, SUCCESSOR_WARP=2]" at line 121
          detected during:
            instantiation of "T cub::CUB_200200_720_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_720_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_720_NS::Sum, SUCCESSOR_WARP=3]" at line 121
          detected during:
            instantiation of "T cub::CUB_200200_720_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_720_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_720_NS::Sum, SUCCESSOR_WARP=4]" at line 121
          detected during:
            instantiation of "T cub::CUB_200200_720_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_720_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_720_NS::Sum, SUCCESSOR_WARP=5]" at line 121
          detected during:
            instantiation of "T cub::CUB_200200_720_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_720_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_720_NS::Sum, SUCCESSOR_WARP=6]" at line 121
            [ 2 instantiation contexts not shown ]
          detected during:
            instantiation of "T cub::CUB_200200_720_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_720_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_720_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_720_NS::Sum, SUCCESSOR_WARP=7]" at line 121
            [ 3 instantiation contexts not shown ]
9 errors detected in the compilation of "/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormKernel.cu".
make[3]: *** [plugin/CMakeFiles/nvinfer_plugin.dir/build.make:2806: plugin/CMakeFiles/nvinfer_plugin.dir/embLayerNormPlugin/embLayerNormKernel.cu.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: Leaving directory '/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/build'
make[2]: *** [CMakeFiles/Makefile2:330: plugin/CMakeFiles/nvinfer_plugin.dir/all] Error 2
make[2]: Leaving directory '/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/build'
make[1]: *** [CMakeFiles/Makefile2:342: plugin/CMakeFiles/nvinfer_plugin.dir/rule] Error 2
make[1]: Leaving directory '/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/build'
make: *** [Makefile:225: nvinfer_plugin] Error 2
atic@ubuntu:/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/build$
Orin Nano architecture is 8.7.
So I did it again as
/usr/local/bin/cmake … -DGPU_ARCHS=87 -DTRT_LIB_DIR=/usr/lib/aarch64-linux-gnu/ -DCMAKE_C_COMPILER=/usr/bin/gcc -DTRT_BIN_DIR=pwd/out
But still have same errors.
[ 82%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/bboxDeltas2Proposals.cu.o
[ 82%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/common.cu.o
[ 85%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/cropAndResizeKernel.cu.o
[ 85%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/decodeBBoxes.cu.o
[ 85%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/decodeBbox3DKernels.cu.o
[ 85%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/detectionForward.cu.o
[ 85%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/extractFgScores.cu.o
[ 85%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/gatherTopDetections.cu.o
[ 85%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/generateAnchors.cu.o
[ 88%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/gridAnchorLayer.cu.o
[ 88%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/lReLU.cu.o
[ 88%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/maskRCNNKernels.cu.o
[ 88%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/nmsLayer.cu.o
[ 88%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/normalizeLayer.cu.o
[ 88%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/permuteData.cu.o
[ 91%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/pillarScatterKernels.cu.o
[ 91%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/priorBoxLayer.cu.o
[ 91%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/proposalKernel.cu.o
[ 91%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/proposalsForward.cu.o
[ 91%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/regionForward.cu.o
[ 91%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/reorgForward.cu.o
[ 91%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/roiPooling.cu.o
[ 94%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/common/kernels/rproiInferenceFused.cu.o
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
            argument types are: (cub::CUB_200200_870_NS::KeyValuePair<float, float>, cub::CUB_200200_870_NS::KeyValuePair<float, float>)
            object type is: cub::CUB_200200_870_NS::Sum
          detected during:
          detected during:
            instantiation of "_T cub::CUB_200200_870_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::ReduceStep(_T, ReductionOp, int, int) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, _T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, ReductionOp=cub::CUB_200200_870_NS::Sum]" at line 388
            instantiation of "_T cub::CUB_200200_870_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::ReduceStep(_T, ReductionOp, int, int, cub::CUB_200200_870_NS::Int2Type<0>) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, _T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, ReductionOp=cub::CUB_200200_870_NS::Sum]" at line 403
            instantiation of "void cub::CUB_200200_870_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::ReduceStep(T &, ReductionOp, int, cub::CUB_200200_870_NS::Int2Type<STEP>) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, ReductionOp=cub::CUB_200200_870_NS::Sum, STEP=0]" at line 449
            instantiation of "T cub::CUB_200200_870_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::ReduceImpl(cub::CUB_200200_870_NS::Int2Type<1>, T, int, ReductionOp) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, ReductionOp=cub::CUB_200200_870_NS::Sum]" at line 530
            instantiation of "T cub::CUB_200200_870_NS::WarpReduceShfl<T, LOGICAL_WARP_THREADS, LEGACY_PTX_ARCH>::Reduce<ALL_LANES_VALID,ReductionOp>(T, int, ReductionOp) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, LOGICAL_WARP_THREADS=32, LEGACY_PTX_ARCH=0, ALL_LANES_VALID=true, ReductionOp=cub::CUB_200200_870_NS::Sum]" at line 204 of /usr/local/cuda-12.2/include/cub/block/specializations/block_reduce_warp_reductions.cuh
            instantiation of "T cub::CUB_200200_870_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::Reduce<FULL_TILE,ReductionOp>(T, int, ReductionOp) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_870_NS::Sum]" at line 354 of /usr/local/cuda-12.2/include/cub/block/block_reduce.cuh
            instantiation of "T cub::CUB_200200_870_NS::BlockReduce<T, BLOCK_DIM_X, ALGORITHM, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::Reduce(T, ReductionOp) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, ALGORITHM=cub::CUB_200200_870_NS::BLOCK_REDUCE_WARP_REDUCTIONS, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, ReductionOp=cub::CUB_200200_870_NS::Sum]" at line 257 of /opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/common/common.cuh
[ 97%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/embLayerNormPlugin/embLayerNormVarSeqlenKernelHFace.cu.o
          detected during:
            instantiation of "T cub::CUB_200200_870_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_870_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_870_NS::Sum, SUCCESSOR_WARP=1]" at line 156
            instantiation of "T cub::CUB_200200_870_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp>(ReductionOp, T, int) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_870_NS::Sum]" at line 207
          detected during:
            instantiation of "T cub::CUB_200200_870_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_870_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_870_NS::Sum, SUCCESSOR_WARP=2]" at line 121
          detected during:
            instantiation of "T cub::CUB_200200_870_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_870_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_870_NS::Sum, SUCCESSOR_WARP=3]" at line 121
          detected during:
            instantiation of "T cub::CUB_200200_870_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_870_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_870_NS::Sum, SUCCESSOR_WARP=4]" at line 121
          detected during:
            instantiation of "T cub::CUB_200200_870_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_870_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_870_NS::Sum, SUCCESSOR_WARP=5]" at line 121
          detected during:
            instantiation of "T cub::CUB_200200_870_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_870_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_870_NS::Sum, SUCCESSOR_WARP=6]" at line 121
          detected during:
            instantiation of "T cub::CUB_200200_870_NS::BlockReduceWarpReductions<T, BLOCK_DIM_X, BLOCK_DIM_Y, BLOCK_DIM_Z, LEGACY_PTX_ARCH>::ApplyWarpAggregates<FULL_TILE,ReductionOp,SUCCESSOR_WARP>(ReductionOp, T, int, cub::CUB_200200_870_NS::Int2Type<SUCCESSOR_WARP>) [with T=cub::CUB_200200_870_NS::KeyValuePair<float, float>, BLOCK_DIM_X=256, BLOCK_DIM_Y=1, BLOCK_DIM_Z=1, LEGACY_PTX_ARCH=0, FULL_TILE=true, ReductionOp=cub::CUB_200200_870_NS::Sum, SUCCESSOR_WARP=7]" at line 121
/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormVarSeqlenKernelHFace.cu(98): error: no instance of function template "cuda::std::__4::plus<void>::operator()" matches the argument list
          detected during:
            instantiation of "void nvinfer1::plugin::bert::embLayerNormKernelHFace<T,TPB>(int32_t, const int32_t *, const int32_t *, const int32_t *, const float *, const float *, const T *, const T *, const T *, int32_t, int32_t, T *) [with T=float, TPB=256U]" at line 117
            instantiation of "int32_t nvinfer1::plugin::bert::embSkipLayerNormHFace(cudaStream_t, int32_t, int32_t, int32_t, const int32_t *, const int32_t *, const int32_t *, const float *, const float *, const T *, const T *, const T *, int32_t, int32_t, T *) [with T=float]" at line 121
          detected during:
            instantiation of "void layerNorm<T,R,P,TPB>(const kvp<R> &, int32_t, int32_t, const P *, const P *, T *) [with T=float, R=float, P=float, TPB=256]" at line 103 of /opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormVarSeqlenKernelHFace.cu
            instantiation of "void nvinfer1::plugin::bert::embLayerNormKernelHFace<T,TPB>(int32_t, const int32_t *, const int32_t *, const int32_t *, const float *, const float *, const T *, const T *, const T *, int32_t, int32_t, T *) [with T=float, TPB=256U]" at line 117 of /opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormVarSeqlenKernelHFace.cu
            instantiation of "int32_t nvinfer1::plugin::bert::embSkipLayerNormHFace(cudaStream_t, int32_t, int32_t, int32_t, const int32_t *, const int32_t *, const int32_t *, const float *, const float *, const T *, const T *, const T *, int32_t, int32_t, T *) [with T=float]" at line 121 of /opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormVarSeqlenKernelHFace.cu
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
          detected during:
9 errors detected in the compilation of "/opt/nvidia/deepstream/deepstream-6.4/sources/TensorRT/plugin/embLayerNormPlugin/embLayerNormVarSeqlenKernelHFace.cu".
make[3]: *** [plugin/CMakeFiles/nvinfer_plugin.dir/build.make:2819: plugin/CMakeFiles/nvinfer_plugin.dir/embLayerNormPlugin/embLayerNormVarSeqlenKernelHFace.cu.o] Error 1
Why do you need to compile and install tensorrt?
In fact on the Jetson platform, tenssorrt is part of Jetpack.
In addition, for Fasterrcnn, you can refer to this repo.
Is it possible to install Deepstream 6.3 into Jetson Orin Nano?
I have this errors.
To run faster rcnn on Jetson AGX Xavier, I followed the instructions here to use deepstream-app.
Yes, of course.
If you want to run on DS-6.3, please switch to the release/tao4.0_ds6.3ga branch.
In addition, I recommend that you read the README directly in the link above.
This instructions seems to be provided by TAO, not DeepStream, not sure if it matches DS-6.3.
