I’m trying to design code which uses controls OPM or ACC based on a configuration-wide preprocessor symbol.
#ifdef GPU_SOLVE
# define CPU_Omp NO_omp
#else
# define CPU_Omp omp
#endif
... <snip> ...
!$acc wait(31)
!$CPU_Omp do PRIVATE_VARS
!$acc kernels async(41)
!$acc loop collapse(3) &
!$acc private(i_pml,i_x,i_y)
do i_pml=2,theGrid % n_pml_bounds-1
do i_y=1+1,theGrid % n_y-1
do i_x=1+1,theGrid % n_x-1
g_z(i_x,i_y,i_pml,1) = g_z(i_x,i_y,i_pml,2)
enddo
enddo
enddo
!$acc end kernels
!$CPU_Omp end do
...<snip>...
This does not behave as I expect: no matter whether GPU_SOLVE is defined or not, (and although I have preprocessing enabled), the !$CPU_omp is not replaced before hitting the directives processing.
(a) Do omp/acc directives get processed before the preprocessor?
(b) If not, why does the preprocessor not replace these instances of the defined symbol?
(c) Is there available documentation on the order of events during pgfort compilation?
