Prerequisites for 5T for 5G feature
I’m interested in a specific feature, “Accurate Scheduling” of “5T for 5G”.
Do I need a EGX A100 edge server to test it or is it OK with a general CPU and ConnectX-6 DX card ?
Thank you,
Kevin
Article about 5T for 5G.
Hi Kwangbaeklee,
Thank you for posting your query on NVIDIA Community Forum.
The referenced link from our Technical Blog has been shared part of an end-to-end solution using NVIDIA products.
In case another vendor server is intended to be used, the check on support for this feature must be made with the server vendor. In addition, the ConnectX-6 DX HCA should also be checked if supported by the server vendor.
Thanks,
Namrata.
