Prevent Thor users from flashing OS
My group has a Jetson Thor that might be testing unsafe/insecure code. I want to prevent end users from being able to reinstall the operating system for security reasons. I have not been able to find any documentation on this.
Is the only way to secure a Thor to physically keep it out of reach for most of our researchers?
hello tandrew,
please refer to developer guide, Secure Boot.
it’s bootloader secureboot prevents execution of unauthorized boot codes through the chain of trust.
once you’ve a target fused to enable secureboot (assume fused with PKC/SBK), you must assign the identical keys for image re-flashing. otherwise it’ll abort the flash process in the very beginning board communication step.
furthermore, here’s a more aggressive approach to prevent reflashing a board.
you may refer to Jetson Thor Series Modules Fuse Specification. it’s bit-23 of FUSE_RESERVED_SW register to disable ability to enter recovery mode.
Hello @tandrew
Physical isolation is not the only option. Jetson Thor supports Secure Boot, which can be used to ensure that only software signed with trusted keys is allowed to boot.
Even if someone has physical access and can enter Force Recovery Mode, Secure Boot helps prevent them from successfully booting an arbitrary unsigned OS image.
RidgeRun has a couple of useful references on this topic:
For Thor specifically, I would also recommend following NVIDIA’s Secure Boot documentation as @JerryChang mentioned when configuring keys and fuses.
Please let me know if you have further questions.
The fuses would be useful, but I would have to be done before the device was shipped to my office. I see this in the link:
The ODM production mode fuse (also known as “Security Mode”) should always be programmed by the ODM on the manufacturing line before the product is shipped to end users.
Am I reading that correctly
Thank you for this information. I see this in the secure boot documentation.
Fuse burning is irreversible and permanently modifies your board.
So this is not something I can turn on and then back off while I test, apparently.
Most PC vendors give an option to put in BIOS passwords. Is that missing for Jetsons?
hello tandrew,
sorry, we’re not supported with a prompt for passphrase by default.
