Hello again,
Running on Archlinux on a laptop with RTX 3060 max q.
I’ve found that prime-run performs far worse than NVIDIA only. I noticed it playing Elden ring, which normally would run great in nvidia-only, on prime-run lags considerably.
Is it a bug?
I used glmark2 to compare nvidia-only with prime-run.
I attached nvidia-bug-report while running glmark2.
For example running glmark2 on nvidia-only it get around 8500 fps on the first test.
[druida@arch ~]$ glmark2
glmark2 2021.12OpenGL Information GL_VENDOR: NVIDIA Corporation GL_RENDERER: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 GL_VERSION: 4.6.0 NVIDIA 525.60.11
[build] use-vbo=false: FPS: 8686 FrameTime: 0.115 ms
[build] use-vbo=true: FPS: 15915 FrameTime: 0.063 ms
On the other hand, switching to prime-run the performance is rather worse:
[druida@arch ~]$ prime-run glmark2
glmark2 2021.12
OpenGL Information
GL_VERSION: 4.6.0 NVIDIA 525.60.11[build] use-vbo=false: FPS: 890 FrameTime: 1.124 ms
[build] use-vbo=true: FPS: 899 FrameTime: 1.112 ms
nvidia-bug-report.log.gz (374.3 KB)
