Prime-select Nvidia won't let my new Asus G14 Boot
I have a brand new Asus G14 Zephyrus 2023 edition with a GTX 4090.
I am running Ubuntu 22.10.1, I have kernel 6.6.6 installed and the latest Nvidia drivers.
When I select intel mode (actually using the AMD integrated) it boots and runs fine.
I tried booting into Nvidia but every time I do I enter the password to unlock the disk encryption and then the loading circle spins either forever, loading circle freezes or it disappears.
Any idea on how I can debug and fix this?
Attached bug report:
nvidia-bug-report.log.gz (859.2 KB)
Running nvidia-smi results in
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I have to boot with prime-select intel, I don’t know if that affects nvidia-smi output
Please delete /etc/X11/xorg.conf
You are a goddamn genius.
Initially, it didn’t work. I had to run update-initramfs -u after deletion.
Thank you so much!
