prime-select regression on kernel 4.15 and up
On Ubuntu 18.04, and as far as I can tell on any Linux distribution with kernel 4.15 or later, switching prime profiles now requires a reboot instead of logout\login which was required up to now.
Anyone knows if this is going to be resolved? Also, is there a possibility we’d get the same behaviour as in Windows, where not even a login\logout is required?
It has nothing to do with the kernel or the driver but Ubuntu changed the prime switch infrastructure completely. See this for info and a third-party fix:
https://devtalk.nvidia.com/default/topic/1032482/linux/optimus-on-ubuntu-18-04-is-a-step-backwards-but-i-found-the-first-good-solution/
To have it like in Windows, the nvidia driver would have to support render offload, which isn’t planned. You would have to use the nouveau driver for that. So no. See:
https://devtalk.nvidia.com/default/topic/957981/?comment=5028916
