printf's won't show since I see no console window :/
Well I have a strange problem… Whenever I execute “fluidsD3D9” I get a console window! Since I based my program on that SDK example, I would expect to get a console window too!
Strangely enough I don’t see one, so whenever I do a printf in my code to print out some data I don’t see it…
Anyone knows how to get such a window?
The console window I’m talking about is this:
Console Window
Are you using visual studio? – Is the project a console application?
What happens if you go to start > run and type in ‘cmd’ to bring up a command window.
Then use the command window to navigate to the directory with the executable and run it?
Hmm if I browse to the .exe file and then execute I get an error… Any idea’s?
